GFrench - EnduroRide Special
  • GFrench
  • GFrench's Avatar Topic Author
  • Supporting Moderator
Replied by GFrench on topic GFrench - EnduroRide Special
Things are cleaning up nicely!
I will be installing my High Compression Head on this bike once I get a 100 miles or so on it... So will not spend a lot of time cleaning/polishing up this stock head - But it is going to look good when finished.
Typically without a doubt I polish the fin edges... but again due to the attitude and look of this bike I may just leave the cylinder all black... We will see how she looks when sitting in the frame.
1971 DT1F MX 250
1973 RT3 360 "Black Widow"
1973 RT3 360
1976 IT 400 / redesigned as a 75 MX400
24 Jun 2014 19:22 #11
Replied by von_7 on topic GFrench - EnduroRide Special
that´s an awesome and very inspiring job. looks so cool!
24 Jun 2014 21:06 #12
  • GFrench
Thank you- it has been a really fun project and will be coming together soon.
1971 DT1F MX 250
1973 RT3 360
25 Jun 2014 06:12 #13
I´m really interested in some details.
How about the Fork, i´m not really happy with the one on my DT-1 either. I´m tall and used extension fork caps to raise the front 30mm, but that doesnt affect the forktravel, of course.
so that fork you are using is from an early dt 400 MX (monoshock model) right?
could you use the triple tree without further modifications?
do you think it would be possible to use the original outer tubes to be able to have the original front fender?
Thanks a lot
Michael
25 Jun 2014 08:34 #14
  • GFrench
Hi Michael- being 6' 5" myself, I understand it for sure.
The front end is from a 1978 Dt400 - Forks and triple trees.
There was no modification needed... just bolted right on.
I am not sure about using the lower tubes from your DT1 with these fork tubes...
1971 DT1F MX 250
1973 RT3 360
25 Jun 2014 17:25 #15
  • GFrench
Wow- talk about Fast Shipping!!
Just ordered this two days ago.
It arrived today-
Will just need to add some clips to pin it in- Fits nice!
Just had to check it out- Nice and Bright-
Perfect look!
1971 DT1F MX 250
1973 RT3 360
25 Jun 2014 19:06 #16
Replied by Makotosun on topic GFrench - EnduroRide Special
So where did you get the headlight? Is it a replaceable bulb? Details, Man - we need details!
25 Jun 2014 21:04 #17
not sure where to get those in the states, here in germany they are quite common:
tinyurl.com/on2vudn
The following user(s) Liked this Post: Makotosun, bluntz465
Last edit: 26 Jun 2014 03:02 by von_7.
26 Jun 2014 03:00 #18
  • GFrench
Company on e-bay- Octane Lighting
5-3/4" MOTORCYCLE 6V HEADLIGHT HEADLAMP HALOGEN H4 LIGHT BULB 6 VOLT 35/35W
And yes it has a replaceable H4 bulb- Will be great when you need to replace and $8.00 bulb!
You want to make sure you go with the 6 Volt 35/35.
1971 DT1F MX 250
1973 RT3 360
Last edit: 27 Jun 2014 10:33 by GFrench.
26 Jun 2014 16:08 #19
  • GFrench
Another small part arrived today-
Decided to go with a more generic control switch on the EnduroFest special to better fit the theme of this bike and not to screw up the original switch that I have.... Plus the colors could not be better!
There are a lot of crap switches out there but this is not one of them!
Very impressed with the quality for just $10.49 on Amazon.
www.amazon.com/gp/product/B00CE0SD0S/ref...00_i00?ie=UTF8&psc=1
Material: PVC, ABS, Heavy duty aluminum housing
1971 DT1F MX 250
1973 RT3 360
27 Jun 2014 19:34 #20
