Connecting CT1 wiring harness to the battery
- Bikingbagga
Connecting CT1 wiring harness to the battery was created by Bikingbagga
Need some help uts not clear how I attach wiring harness to the battery, I do not see any wire that I hook up to the postive terminal of the battery
What am I missing? It would be helpfull if I coudld actually speak to someone who is in the know
thanks
Rob
thanks
Rob
25 Feb 2025 11:51
Replied by MarkT on topic Connecting CT1 wiring harness to the battery
Red wire. There should be 3 red wires with connectors in the vicinity of the battery. Two of the three red harness wires have female bullet connectors and should have a fuse holder connecting them together. The third has a male bullet connector that plugs into the female connector on the battery.
Pic of fuse holder: cdn.shopify.com/s/files/1/0570/0553/9488...-00.jpg?v=1654319151
25 Feb 2025 12:10
- Bikingbagga
Replied by Bikingbagga on topic Connecting CT1 wiring harness to the battery
Thanks Mark
Per your picture the fuse I have is the same connected looks like a loop
I do not see a third wire to connect to the battery amywher I have attached photos of what I have
25 Feb 2025 12:31
You need to use a third party like Imgur or Google photos and post a link here.
The direct photo hosting here is broken
25 Feb 2025 12:45
- Bikingbagga
Dont really know how to add photos from another source Im not savy enough I guess
25 Feb 2025 13:24
- Bikingbagga
Im unable to load photos so does anybody have a photo of what it should look like as I dont have a postive wire that I can attach to the battery
I can add it but the wiring harness looks to be stock so I was expecting to have a wire I dont see it anywhere
25 Feb 2025 13:36
Not sure exactly which year model "CT1" you are working on?
From memory, the red to the battery on earlier harnesses comes out of the harness right where the rectifier wires enter the harness. Rectifier has a red and white going to it. A short section of red wire with the male bullet comes out right where the rectifier wires enter the taped harness.
25 Feb 2025 13:50
- goatboy56
Replied by goatboy56 on topic Connecting CT1 wiring harness to the battery
DT2 - the red for the battery comes out closer to the front. Would have to go out to check on CT's but this was easier to photo.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
25 Feb 2025 13:53
My 71 CT1b is in storage and boxes at the moment. If you ID exactly which year model you have, I also have a box of wiring harnesses and can probably find a harness to send pics of if someone else doesn't have a pic on the bike.
25 Feb 2025 13:56
- Bikingbagga
I have a 69 CT1 just had the stator rebuilt by Ricks Electric they completly rebuilt it with new wiring one of the wires that came out of that was white with red rings around it I plugged that into the red wire of the harness which in hindsight is the red wire that goes to the battery
Problem now is I have 5 wires coming out of the stator and one wire that goes to the neutral switch I only have 4 wires left in the harness yet I have 5 wires from the stator
Could not be anymore confused that I am now
Does all the wires from the stator get plugged in or one thats not used?
Really be helpfull if I could face time or whatsapp with someone so they can see what I have and help me work through it
Trying to find wiring diagram for the 69 CT1 as my vin number is CT1-004822 and the diagrams I see are for the CT1A CT1B CT1C so which diagram do I look at as it does not have a CT1
My magneto has yellow black green gray and a white red wires I was able to match up these wires to my harness according to CT1A diagram the white/red wire is just hanging out
