1974 DT360 Disassembly and Restoration
  • pabdt
  • pabdt's Avatar Topic Author
  • Online
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 1974 DT360 Disassembly and Restoration
started powder-coating some parts:
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
26 Apr 2020 09:24 #81
Replied by mdscott on topic 1974 DT360 Disassembly and Restoration
Is that heat resistant tape on the triple tree?
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
26 Apr 2020 13:08 #82
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
both tapes are high temp. seems I may have messed up:
The tray for the handle bars should be bare or coated? May have to redo this.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
26 Apr 2020 14:59 #83
Replied by 2fishkev on topic 1974 DT360 Disassembly and Restoration
I would say bare. That’s what I did anyway. I stripped every spot I could and had no grounding problems when done. Nice work. I liked it when I got to roller status. Fun to look at and study.
26 Apr 2020 17:38 #84
Replied by Mothersbaugh on topic 1974 DT360 Disassembly and Restoration
"The tray for the handle bars should be bare or coated? May have to redo this."
MarkT was just telling someone else in a horn thread that the switch casing has to ground to the bars, and the bars have to ground through the triple tree, so bare-naked is just fine.
26 Apr 2020 18:12 #85
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
I can not wait for roller status. Gotta see if I can rebuild rear shocks or find others.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
28 Apr 2020 10:53 #86
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
Steering lock removal complete. I used a 5/16" drill bit, slight amount of oil anticipating hard metal/heat and carefully drilled out the old lock. The metal was very soft and fairly easy to remove.
Started work on rear shocks. Thought I would post up my shock spring tool. It was made from basic stuff around the garage and seems to work fairly well. There is another piece not in picture. Same as base square metal stock but attaches up top also to keep it from spreading for stiff springs.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: MarkT, Gerryz
Last edit: 30 Apr 2020 18:27 by pabdt.
30 Apr 2020 18:22 #87
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
disassembled one of the shocks today: To my surprise still had about 20 ml of shock fluid. Overall shape was ok, but seal cap was deformed. I'm not thinking this is a show stopper though. I'll add seals and see how it works out.
Plan to power-chrome the spring and adjustment ring and black out the low half of shock and reservoir. Replacing the mounting bushings would be nice. going to have to take them out anyway.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Last edit: 02 May 2020 20:55 by pabdt.
02 May 2020 20:53 #88
Replied by Camp3 on topic 1974 DT360 Disassembly and Restoration
I'm working on my DT250 and used the seals from the website below, maybe you seen it already. What is "Power-Chrome". I just vapor cleaned the springs, evidently the process "peens" over the metal and closes the pore so it doesn't rust as quicky. I also put a coat of clear on them, they look ok a bit pitted. Maybe the clear won't chip off immediately. Eventually I'd like to get new springs. They look good at 20 feet but not so great close up.
www.nthrepro.com/
1976 DT175C
1975 DT100B Kid Trainer
1974 DT250A In Process
1992 FJ1200
03 May 2020 06:05 #89
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
That’s powder coat color “super chrome” plus a clear coat. Thanks for link to the seals.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
03 May 2020 12:10 #90
