1974 DT360 Disassembly and Restoration
Replied by Snglsmkr on topic 1974 DT360 Disassembly and Restoration
There is a tire thread on the forum that may help you decide. I recently put Perelli's on mine.
20 Mar 2020 04:59 #51
Replied by jmagda on topic 1974 DT360 Disassembly and Restoration
Hunney hush!
20 Mar 2020 05:06 #52
Replied by yamahoper on topic 1974 DT360 Disassembly and Restoration
Just mounted these Tusk Adventure. Have only done road test so far= low vibration, good grip on dry pavement. They seemed very stiff when mounting . The rear 120/90x18 was a max allowable width and does go all the way forward on chain adjuster with about 1/8" clearance on chain guard. There was a sale at rocky mountain in December on these tires I think because the rear was backorderd for 2 months .
The following user(s) Liked this Post: MarkT, Jack
20 Mar 2020 06:32 #53
Replied by darinm on topic 1974 DT360 Disassembly and Restoration
Those tusks are great off road too but hard to mount. I eventually took the rear into the shop after too many pinched tubes.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
20 Mar 2020 11:56 #54
  • pabdt
  • pabdt's Avatar Topic Author
  • Online
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 1974 DT360 Disassembly and Restoration
That tire looks like it could tread over nails, fire, and glass and laugh at the other end .
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
20 Mar 2020 19:44 #55
Replied by MarkT on topic 1974 DT360 Disassembly and Restoration
Came across this a while back... might help... basically just a longer spacer and longer bolt.
The following user(s) Liked this Post: RT360Fan, mdscott, JayB, Gr8uncleal, Super90, Jack
Last edit: 20 Mar 2020 20:15 by MarkT.
20 Mar 2020 20:13 #56
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic 1974 DT360 Disassembly and Restoration
Awesome info Mark - thanks very much.:likey
21 Mar 2020 01:07 #57
Good one Mark, there may be a clearance issue on the exhaust of a 74. I mounted the tusk tire on a 76 400C which has a flattend exhaust section next to the shock for extra clearance.
21 Mar 2020 08:40 #58
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
got the rear wheel done. Will post the part#s sent to me by Buchanan Spokes, they were a perfect fit for front and rear wheels.
The front wheel was a "real fun" to get trued. The rear wheel came out with little to no vertical/lateral run out. In any case, save the hubs and wheels.
pic of the rear wheel assembly:
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: MarkT, Snglsmkr, Schu, Super90
Last edit: 29 Mar 2020 17:26 by pabdt.
29 Mar 2020 17:21 #59
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
glass blasted the upper and lower triples today. The aluminum upper was glass beaded, then quickly polished w/alum oxide.
waiting on powder to come in, but for now this was worth a pic. Could almost install it as is.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: Makotosun, Snglsmkr, Super90, Deebs71
11 Apr 2020 14:41 #60
