1974 DT360 Disassembly and Restoration
Replied by RT325 on topic 1974 DT360 Disassembly and Restoration
I'm probably sounding like broken record but tighten the flywheel good & tight. Especially if those run no key at all.
I guess they runs a 12 volt lighting setup with regulator rectifier & battery so should be great.
01 Jun 2024 05:10 #221
  • pabdt
  • pabdt's Avatar Topic Author
  • Online
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic 1974 DT360 Disassembly and Restoration
Update to post 211: How to set kickstarter spring tension .
If you already have your crankcases apart, you can see the tension on the spring. If you look back in some of my pics in this thread you will see the tension on the spring inside the R crankcase.
The spring is angled at about 2 and 8pm or there about. Point the ratchet stop at 2pm, engage the spring, put the kick starter lever temporarily on the shaft and turn 180 degrees counter-clockwise, then somewhere around 45 +/- degrees to clear the stop, push the shaft gently while turning L/R, and it will slip in place.
Some of this is in the service manual, however it recommends taking note of spring install position when removing the kick starter. In my case, I also installed with the gear removed so the clutch didn't interfere.
Putting decompression cable on engine Sat. Might be engine install day!
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
Last edit: 07 Jun 2024 21:50 by pabdt.
07 Jun 2024 21:49 #222
I recon when they were designed they must've had a prize for who could design the most annoying kick start spring.
Plus, if it breaks then it's a total dismantle job.
07 Jun 2024 22:52 #223
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
engine back on frame...
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: Dirtboy, Schu, Ht1kid, Sneezles61, Tinkicker
09 Jun 2024 20:00 #224
  • Reed valve Richards
  • Platinum Member
  • Platinum Member
Replied by Reed valve Richards on topic 1974 DT360 Disassembly and Restoration
Looking goooood !
Yo Joe, Go Joe
09 Jun 2024 20:17 #225
Yes looking good for sure. Those pics are so clear when expanded up. Everything nice & shiny.
I'd better not mention the tits broken off both breathers--they do that, & i know they'll be replaced.
I wonder i they were made of black matterial maybe they wouldn't go brittle.
Not far off start up now so looking forward to the big moment. That's always exiting.
09 Jun 2024 22:24 #226
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
a little progress, a little redo of a some things too. Took the tach gear out to replace new seal and o-ring.  The R cover gasket seemed to brittle and didn't fit right. Pulled cover, wife did a great job painting the yamaha log on, and
best thing that happened today was created a new tool:
M6x1.0 Thread chaser/cleaner:
Cut about 4 slits in a M6x1.0 bolt. Bolt in pic 25mm.   I keep a can of WD40 and B3 Cleaner. Then attaching an allen wrench I cut off for use on a cordless drill with torque control, set to low torque and enjoy.   I used B3 to clean bolt on removal and 1 shot WD40 for cleaning threads.  Yes, you could use a tap, but they are a bit more aggressive.
I
Thanks Mrs pabdt for painting the letters:
had to reorder a new gasket for R cover, but am working on wiring today, chain, few other things.  R1 in background.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: Ht1kid, Sneezles61, Tinkicker
15 Jun 2024 18:29 #227
Replied by Eflrr96 on topic 1974 DT360 Disassembly and Restoration
Have you finished getting this all up and working? If so how is the stability of your lights at night? I noticed with my vape 12v system that the lights still drag down quite a bit at idle.
I’m either livin’ the dream or dreamin’ of livin’!
05 Jul 2024 08:22 #228
  • pabdt
  • Online
  • Platinum Member
  • Platinum Member
I have wired things up, but no testing yet. I'll post a video up when done.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: Eflrr96
06 Jul 2024 01:11 #229
Yesterday while going over the bike again I found a wire that was unused by the Vape system that I hadn’t put heat shrink on the end and was causing trouble. Once I’d put the heat shrink I took it out after dark and everything was as I’d expected and strong lights all the way around with very little dimming when using multiple different lights at the same time.
I think you’ll love the difference!!!
The following user(s) Liked this Post: Snglsmkr, pabdt
Last edit: 06 Jul 2024 03:58 by Eflrr96. Reason: Misspelled word
06 Jul 2024 03:57 #230
