1974 DT360 Disassembly and Restoration
- pabdt
Replied by pabdt on topic 1974 DT360 Disassembly and Restoration
Thanks, but there were problems w/the paint job and I decided to redo it. Its going to make the previous work look like crayons.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- pabdt
I said a few posts back I would post part numbers from Buchanan Spokes. The spokes fit perfectly. Easier to read directly off my receipt. BTW, these fit
the stock 1974 rims and hubs.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- DT Tim
Replied by DT Tim on topic 1974 DT360 Disassembly and Restoration
Looks beautiful to me, well done for a non paint guy!
One point to note, painting the thread of the oil tank filler hole, PO did this on mine and I was getting paint flakes in the oil, the 2t oil was breaking it down, and with the friction of the cap in the threads it was coming away.
29 Apr 2021 23:22
#163
- pabdt
roger that.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
05 Jun 2021 19:23
#164
- pabdt
Roger that Tim...and thanks
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
05 Jun 2021 19:25
#165
- pabdt
Prepping engine halves for assembly...got a call today and the rod is pressed on and cylinder is ready!
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
05 Jun 2021 19:32
#166
- pabdt
not bad for a 47 year old crank! new rod, bearing and thrust washers.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Replied by RT325 on topic 1974 DT360 Disassembly and Restoration
Lookin good except the last image is missing. Of course i want to see it even more now haha. I note the detent plunger cap is in place. If you did that to protect the thread while painting then all good. Just want to be sure the plunger & spring are in your box of bits & not dropped out & rolled under the compressor--"like my stuff does" & hides.
07 Jun 2021 23:17
#168
- pabdt
Whew! I had to go to the garage and check after reading this. they are on the table. with all the air gun action outside, surprised I haven't blown them down the driveway. last pic showing up now?
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- pabdt
Please let me know if this order of crankcase assembly would work well. (Note; R=oil pump side, L=mag)
1, Freeze L bearing. Heat L crankcase using propane torch around bearing area. then install bearing.
2. Freeze R bearing. Heat R crankcase, install bearing.
3. Install remaining case bearings in similar manner.
4. Cool down then install L and R seals.
3. Freeze crank, install in R, then left crankcase as quickly as possible w/case assembly tool. I'll be using "Yamabond 4"
(or should I freeze crank and heat innter bearing race, then install seals after cool???)
I have an assembly tool I need to review how to use...Also, when is best to install seals? Before or after crank?
Please people keep in mind, I'm thinking out loud. Have not looked at this in some time. Looking for advice on assembly.
I figure once I have the crank halves together, things should be a bit smoother.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
27 Apr 2024 17:42
#170
