My DT2
Replied by AirborneSilva on topic My DT2
DEET did mine on my 76 DT400, they look brand new again. I'm going to have him restore the ones on my DT2 and repair the tack for my DT400 that I screwed up over revving the motor - had a runaway throttle. I recommend all of his work, he's done the key switch on my DT2, good as new!
The following user(s) Liked this Post: Ht1kid, Brzn
08 Oct 2022 10:28 #81
  • Brzn
  • Brzn's Avatar Topic Author
Replied by Brzn on topic My DT2
I purchased the painted parts to my bike this past summer. Got the vinyl graphics for the gas and oil tank as well as a NOS 250 emblem and aftermarket Torque Induction emblem for the oil tank. Took everything to a local PDR guy to pull some dents and dings and now have them to a body shop to be painted the original '72 Pearl Yellow Gold. I'm keeping the original pieces for the patina.
From Dave at KDI Reproductions I bought the Gas Cap. It really appears to be a top quality piece. For just under $60 US it comes complete with all the parts; gaskets, springs, pin, clip, et al. Weight is just slightly more than an original Cap.
For $60 US the reproduction makes my OEM one about worthless!
27 Oct 2022 11:33 #82
I also bought one of those gas caps from KDI, how long did it take to get yours?
27 Oct 2022 12:02 #83
  • Brzn
Maybe 10 days? I'm on the east coast, he's on the west and it came USPS.
27 Oct 2022 13:36 #84
Thanks, I'm on the east coast as well and it's been 10 days for me as of now.  I did contact him today, he gave me the tracking number and of course USPS shows it as still in LA.  Oh well at least the one I have now is still working so no big deal, just thought maybe he forgot since it was a phone order and not internet.  Thanks again...
27 Oct 2022 13:44 #85
Replied by SKYDANCER46 on topic My DT2
Hey BRZN,
Did you notice any improvement in how your bike ran after the heat gun burn out of your exhaust pipe? Do you think it helped?
27 Oct 2022 20:30 #86
  • Brzn
I couldn't notice any improvement in performance, however it seemed a wee bit louder to me.
28 Oct 2022 02:41 #87
Replied by MarkT on topic My DT2
The downside of getting pipe red hot is it generally burns up the thin sheet of fiberglass mat under the perforated steel that lines many of the stock pipes.
28 Oct 2022 08:33 #88
  • Brzn
I didn't let the pipe get any hotter than 460F trying not to destroy it's insides. The 460F was close to the outlet where I had the heat gun inserted. As soon as the pipe stopped smoking I shut the heat gun off and used compressed air for a bit.
29 Oct 2022 04:56 #89
  • Brzn
First off a big shout out and thank you to a few that have helped me through a few things over the past several weeks;
MartT
RT325
Bill - 1971DT250
Pete-RT1
SKYDANCER46
Thanks Guys!
Over the past several weeks I've addressed several items that needed a bit of attention. I'm fairly mechanically inclined, and not scared to jump into mechanical work, just need some guidance every now and then.
The carb - issue a bit of what's best described as a miss between 3500 and 4500 RPM's. I'd cleaned and rebuilt the carb last year, but it needed more. I was able to get the Main Nozzle out and clean it, then re-installed the original Mikuni Needle Jet, cleaned the Main Jet's Banjo Bolt and re-installed the original Mikuni #160 Main Jet.
The Cylinder Jug Base Gasket - issue slight leak from the left front corner. Afraid if oil's leaking out air could leak in. Last year I'd replaced an obviously leaking Head Gasket, and with the head off I turned the crank over slightly separating the Cylinder from the Case. Oil came out from between the two when I did that.
After two failed attempts of purchasing the base gasket
I got the right one
Here's what the piston looked like when I pulled the cylinder
I removed the piston and the rings (there's an expander ring behind both the top Dykes L ring and the bottom one) and cleaned off all the carbon carefully with 400 grit sandpaper. I believe the piston looked as bad as it did due to blow by from the bottom ring being stuck in the groove with carbon. I was able to get the bottom ring out and get it's groove cleaned out. I also cleaned the carbon out of the head.
Not too bad for 3,400 miles
The following user(s) Liked this Post: Rick C., Pete-RT1, Sneezles61
06 Nov 2022 13:09 #90
