"Money Maker" 1974 Yamaha DT 250
Replied by Devin on topic Project: "Money Maker"
Old turn signal switch. It worked fine before removed. The black sleeving was so old, and brittle, it cracked. I will throw it in the bin of parts to rebuild.
New switch: It did not come with the rubber sleeve. I had to remove it from the old switch and swap it over.
New front and rear brake switches.
Last edit: 20 Nov 2015 14:50 by Devin.
28 Jul 2014 12:47 #51
Another switch to rebuild. The old ignition switch worked fine. It had an exposed wire that had been taped with electrical tape. Picked up a new switch.
I found this amusing. I did not customize my plate. The DMW gave me an MX plate lol.
Some hardware to install the plate. Safety is my #1 concern.
Last edit: 20 Nov 2015 14:51 by Devin.
28 Jul 2014 12:53 #52
Polished the old levers.
28 Jul 2014 12:59 #53
I did not have any before pictures of the bike. I even started to work on my next project and realized I only had 1 photo. I will make sure I take many "before" pictures, before the full tear down on rumble bee (78 DT 400) begins.
Its nice having a roller and I can twist the throttle. Cant wait to get this bike out on the road. I am going to bolt all the parts on, and will be finishing the engine.
The following user(s) Liked this Post: Wheels
Last edit: 20 Nov 2015 14:53 by Devin.
28 Jul 2014 13:08 #54
Sorry, I have no before picture on this one. It had normal wear and tear, for a 40 year old casing. I wonder what was originally above "Made in Japan"?
I thought about adding a little decal here.
28 Jul 2014 16:51 #55
Last edit: 25 Aug 2014 21:59 by Devin.
28 Jul 2014 16:58 #56
Someday you will own a Yamaha ;)
28 Jul 2014 17:00 #57
Replied by Scootern29 on topic Project: "Money Maker"
It probably had a decal for the shift pattern in that slot. Only a guess on my part but I have seen them on other bikes.
Last edit: 25 Aug 2014 22:00 by Devin.
28 Jul 2014 17:25 #58
Replied by Makotosun on topic Re:Project: "Money Maker"
Very nicely done!
Posted from my iPhone from the Wild!
28 Jul 2014 17:27 #59
Replied by Devin on topic Re:Project: "Money Maker"
Today, I have been working on the front end. I am taking a break, then I will go back and work on the back.
I cleaned up the cable guide. It looks like it was bent. I straightened it up a little better.
Took the headlight assembly apart and cleaned it up.
Last edit: 20 Nov 2015 14:54 by Devin.
29 Jul 2014 19:39 #60
