RT1 Restoration
- DEET
- Moderator
Replied by DEET on topic RT1 Restoration
Could the leak be coming from the bottom of the cylinder?
Maybe traveling up through the stud/cylinder bolt hole and appearing at the top of the cylinder?
The following user(s) Liked this Post: MarkT, pabdt
- Pete-RT1
Replied by Pete-RT1 on topic RT1 Restoration
Deet, it could be although the stud holes are outside the perimeter of the liner.
Also, the base gasket shows no signs of leakage with soapy water.
I might not be able to confirm the leak path.
Can you see any problems with having the cylinder skimmed and a full face copper gasket?
Yamaha CT3 (in bits)
21 May 2021 14:06
#52
- DEET
- Moderator
If the leak is at the base gasket near a stud.... and the escaping air travels up around the stud.... then the air escapes around the cylinder bolt which is screwed to the stud.
It has nothing to do with the liner.
Just a thought....
Just a thought....
21 May 2021 14:33
#53
Replied by RT325 on topic RT1 Restoration
Quote thing just comes up Error in red, so copy & pasted in the end.
RT325 post=128212
How about pressure testing again incase like i said, coming up the outside of the cast in liner. They are a good sealing head normally. Might be better not to know haha.
Ok, so back to as i said here, & better not to know. Just put her together & it'll be fine. Was ok before ya knew all this & ran good for a hell of a long time looking at the piston before you cleaned it. Defo not going to test mine as i'm sure 'll loose sleep over it if i do haha.
RT325 post=128212
21 May 2021 15:01
#54
