1983 IT 490K "Refresh"
  • Biknflyfisher
  • Biknflyfisher's Avatar Topic Author
Replied by Biknflyfisher on topic 1983 IT 490K "Refresh"
Got 3 good coats of paint on the exhaust system, so now it can hang in the garage for a few days next to the ultra- fast FJR1300 and they can "bond" as fellow Yama-Bombers.
Hopefully my parts will come tomorrow so the project can move forward.
Cheers, and enjoy your Sunday night!
Brian the biknflyfisher
1983 IT490K; 2007 Yamaha FJR 1300,
2003 KTM 450exc
Too many fly rods,,,
08 Feb 2015 17:03 #21
  • Biknflyfisher
Pony Express finally showed up today,,,,,
New headlight lens, new front muffler stay, exhaust manifold gasket, rubber attachment grommets and a clutch cover gasket. Looks like fun in the garage tomorrow night,,,,
In looking closely at the newly painted expansion chamber, I found a spot where the paint was a skoosh thin, so I'll need to spray a bit more tomorrow in the daylight.
biknflyfisher
2003 KTM 450exc
09 Feb 2015 20:41 #22
  • Biknflyfisher
Any opinions out there on the best way to remove cruddy old decals from a PLASTIC gas tank?
Clearly the hot air gun method on a metal tank works well, but what about plastic?
Thanks all,
Biknflyfisher
2003 KTM 450exc
12 Feb 2015 06:46 #23
Replied by GFrench on topic 1983 IT 490K "Refresh"
I use a Hair Dryer (NOT A HEAT GUN!!!) to heat up the decals and they will loosen up enough where you will be able to pull them off.
Then I use a little Acetone to remove the glue residue.
To clean that tank up- try some steel wool and Goo Gone and it should brighten it up a tad. Once they are stained with the fuel/oil mixture pretty tough to get that out but you could do some wet sanding to get the top surface off to see if that will bring the tank back.
1971 DT1F MX 250
1973 RT3 360 "Black Widow"
1973 RT3 360
1976 IT 400 / redesigned as a 75 MX400
The following user(s) Liked this Post: Biknflyfisher
Last edit: 12 Feb 2015 16:14 by GFrench.
12 Feb 2015 07:08 #24
  • Biknflyfisher
Thanks Greg - great info!
2003 KTM 450exc
12 Feb 2015 11:58 #25
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=230288224273&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • Biknflyfisher
Yup, I ordered those very same decals this morning before I headed into the office.
Tonight's plan was was to put the new Maxima 10wt fork oil in the forks AND increase the oil level to 160MM, BUT the Motion Pro tool didn't come in at the dealership today - bummer. So, maybe just have a few glasses of wine and hang out with the sick wife,,,,,
I'm letting the newly painted expansion chamber and silencer cure a bit more before they get installed.
Last night installed the new headlight lens and dumped the old fork oil, which looked pretty "tired".
Biknflyfisher
2003 KTM 450exc
12 Feb 2015 18:03 #27
  • Biknflyfisher
Good news, the Motion Pro fork oil level kit arrived today at Wilson's Motorsports. So, tonight I was able to refill the forks with Maxima 10wt oil, and I increased the oil level to 180mm (standard setting is 170mm). I figured that the factory springs might be a bit soft, and the increased oil level would keep things from bottoming low in the stroke.
The forks are done!
As I was still on a roll, I went ahead and got the forks mounted, torqued down the handle bars and the triple trees. I mounted the wheel as well, but didn't torque that as I cannot seem to find my 24mm socket. Looks like a trip to the hardware store is in the works for tomorrow.
The Blue Bomber is starting to resemble his old self again,,,
Enjoy your Saturday, and get out and ride!
Biknflyfisher
2003 KTM 450exc
13 Feb 2015 23:37 #28
Replied by AT6 DRIVER on topic 1983 IT 490K "Refresh"
I wish I would have known about these decals before I bought some cheap crappy ones! I need to go and buy these to replace the cheesy ones I just put on.
1975 DT 400B
If it moves and shouldn't , use duct tape. If it doesn't move and should, use liquid wrench.
14 Feb 2015 18:51 #29
Replied by mike1995 on topic 1983 IT 490K "Refresh"
I needed to replace the decals on my 1975 DT 250. The kit I purchased was from Speed and Sport, AKA "Wicked Tough". They have videos on line regarding installation. The main difference with the kit I installed is that the decals must be clear coated afterwards for the metal tanks. Great products, they also have a great selection NOS parts for Yamaha's.
15 Feb 2015 06:53 #30
