1973 headlight help. I messed up?
Replied by RT325 on topic 1973 headlight help. I messed up?
Just a thought & not sure how legal you need it for the road but anything from this side of the world would or should be left hand dip where the US have right hand dip. I recall when we sold Harley's & we had to change the headlight unit. Was very noticeable if you had do dip it for oncoming traffic at night & couldn't see the line on the side of the road. I'm in NZ by the way & all our yamahas came under Oceania if i remember right. I did google oceania yamaha parts but go nowhere.
20 Aug 2018 02:45
#11
Replied by MarkT on topic 1973 headlight help. I messed up?
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=222960897754&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by Gr8uncleal on topic 1973 headlight help. I messed up?
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=282728080425&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
- Joseph_siller
Replied by Joseph_siller on topic 1973 headlight help. I messed up?
That makes perfect sense thank you! So what would be a good setup if I wanted run a led? I want something where I can just replace if it goes out like you were saying earlier.
20 Aug 2018 12:48
#14
- Joseph_siller
So what you’re saying is it’s just like a stock headlight but you can replace the bulb whenever you want but you have to buy the brackets to hold the bulb in?
20 Aug 2018 12:53
#15
No brackets needed... look at the Pobit sealed beam option on ebay. It comes with wire clips to hold the light into the rim like the later models. Clips are #10 in diagram.
I like the MikesXS clips... looks like they are out of stock... you get 5 and I usually destroy one or two which leaves me the three left I need to hold the light in place.
www.mikesxs.net/yamaha-xs650-headlamp-w-clips-pk-5.html
20 Aug 2018 19:35
#16
Joseph
Over the years Yamaha appear to have switched between sealed beam units and ones where the bulb could be replaced. An awful lot of the early models were fitted with lights manufactured by Koito.
What I did was to scour ebay on a regular basis looking at all old Koito units and also Yamaha headlight buckets with YHA107 stamped on them. I ignored which model the vendor stated that they were off because a) many owners chopped and changed parts and therefore the bike that it eventually came off might not have been the bike that it was originally fitted to and b) many parts were interchangeable between models. I had to pay very close attention to the location of all of the mounting holes and also the long adjusting screw. I did make a couple of errors along the way though!
As I understand it, the spring mounting clips (that hold the glass inside the chrome headlight rim) on the aftermarket lights replace the small screws on the original headlight that did the same job.
I can't help with led lights I'm afraid, as that's well beyond my skillset!
All the best and good luck with your search.
21 Aug 2018 00:28
#17
- Joseph_siller
So I can change bulbs out on this one? All I need it the clips? And would I be able to run a LED?
21 Aug 2018 07:29
#18
No, the pobit lamp is sealed beam, just like your original.
21 Aug 2018 08:08
#19
Not sure what "this one" is... the one in post #12 has a replaceable H4 6v 35 watt halogen bulb...
There are many replaceable bulb H4 reflectors like it to choose from. Most have no bulb (sold seperately) or a 12v 55 watt bulbs so you also need to get a 6 volt 35 watt bulb.
Yamaha headlight runs on AC power. LED's need DC power. I have not seen an LED that will work unless you change the system to DC power.
21 Aug 2018 08:30
#20
- Home
- Forums
- Community
- Tech Library
- Market
- User Menu
