DT3 headlight
  • fossilrider
  • fossilrider's Avatar Topic Author
DT3 headlight was created by fossilrider
Being a computer idiot isn't fun..... but I confess, I am. I THOUGHT I posted a message a few days ago asking for help with a headlight solution for my DT3, but I don't think it ever got posted.? I have such a hard time navigating some of these sights, while others seem to be easier for me. So, I hope this gets through. My bike had no headlight, when I got it but I had a later '74-'79 or so without a lens/bulb assy., which I had already painted for the CT3 I did a couple years ago, but didn't use. So I put it on the DT thinking I would find a lens assy. for it. I did, but at $50 or so for a used one and $150+ for a new one, I think I will do some creative thinking. And ask for input, of course. Surely others have had this same problem and found an AFFORDABLE solution. My bike is not a 100 point resto so authenticity doesn't matter. I realize, being 6 volt, the options are slim but does anyone have any advice? Thanks in advance. I also still need a wiring harness for the same bike. Steve
12 May 2017 11:22 #1
Replied by 1971DT250 on topic DT3 headlight
How about this:
12 May 2017 13:22 #2
  • fossilrider
Replied by fossilrider on topic DT3 headlight
Thank so much! Was this on ebay? If so, I must have totally overlooked it. Exactly what I was looking for. This site is so awesome. I hope I can repay by helping others in the future. I immediately bought it. Best to you. Steve
12 May 2017 14:05 #3
Replied by MACE6772 on topic DT3 headlight
Make sure you check ALL of the bulbs on the bike BEFORE you start it. Balanced system, all bulbs need to be good. Burned out my OE Kioti (one of those expensive ones) headlight when i skipped this step.
12 May 2017 17:21 #4
Replied by 70shovelhead on topic DT3 headlight
Take a look at this bulb from J & P Cycles..
www.jpcycles.com/product/310-087
70SHOVELHEAD
1937 Harley WL45
1962 Cushman Silver Eagle
1974 DT250
1974 DT360
1973 CT3 175
1975 QT50
1975 Honda NC50
1986 Suzuki FA50
12 May 2017 18:42 #5
  • fossilrider
I have one of those. They are about 1/2" or so too big in diameter. But thanks.
12 May 2017 19:20 #6
  • fossilrider
Thanks for that heads-up. I know some of the early Yamahas would blow the headlight bulb when you reved them up, if you didn't put a voltage regulator in the system. Steve
12 May 2017 19:22 #7
  • fossilrider
Well, I guess I jumped the gun. I bought the sealed beam, and I guess I didn't read the listing well enough. This is the same item I already have. The listing states that it fits "many" Yamaha endures from '68 to (I don't remember, maybe '80 or so). Anyway, it is the 5 3/4" dia. bulb and does NOT fit the bucket I have, which I'm pretty sure is a '74- about '78 DT. I need a bulb that is about 5" and those are the ones that I have been seeing for $50 (used) to as much as $150 (new). I have been told to find one of the black plastic units from a DT100 (and others, I think) from '77 onward. Anybody tried these? The search continues.
18 May 2017 16:44 #8
Replied by BankruptinPA on topic DT3 headlight
What I used is Octane Lighting 5 3/4" Motorcycle 6 volt headlight with H4 bulb 6 volt 35 watt, plugs in perfect, bulb is slightly longer so the fit is tight and you can change the H4 bulb with an LED and get the Motorcycle "W" Clips from ebay that will secure it to the chrome headlight face
Last edit: 29 May 2017 04:10 by BankruptinPA.
29 May 2017 03:53 #9
  • fossilrider
Thanks for the reply but, like I said in my post, a 5 3/4" dia. bulb will not fit in my 5" bucket. I thought I was getting an item that would fit twice before only to find out, after they arrived, that they were 5 3/4". So I have two 5 3/4" dia. sealed beams on the shelf now that I can't use. Since the 5" dia. bucket obviously is so hard to find a bulb for, I have been looking for a 5 3/4" bucket. But thanks anyway.
29 May 2017 05:50 #10
