1978 Yamaha DT400E Rear Blinkers
  • Mini Enduro Man
  • Mini Enduro Man's Avatar Topic Author
  • Supporting Moderator
1978 Yamaha DT400E Rear Blinkers was created by Mini Enduro Man
This post is to help others from making my mistake.
If you purchase the K&S rear blinkers for the 1978 Yamaha DT400E or the 1978 DT250 Buy the K&S aftermarket ones that are MFG. # 25-4015
do not buy the 4016.... the installation shaft is too short.
The following user(s) Liked this Post: Makotosun, Devin
07 Aug 2014 09:05 #1
Replied by Makotosun on topic 1978 Yamaha DT400E Rear Blinkers
I had that problem too with a set of the overseas repops. I was able to salvage the purchase and use them by using a razor knife to carefully slice off about 1/4" of the rubber base, effectively extending the metal shaft. The side benefit was blinkers that were 1/4" narrower on each side which keeps them that much more out of harms way! Not a bad unintended result!
07 Aug 2014 09:33 #2
Replied by cdr on topic 1978 Yamaha DT400E Rear Blinkers
Thank you Mini Enduro Man.
This post was very helpful in getting the correct rear blinkers for my 1978 DT400.
The following user(s) Liked this Post: Mini Enduro Man
24 Apr 2022 18:18 #3
