Choke problems
- Pap
Choke problems was created by Pap
Looking for help I have a 75 dt 175 starts fine and runs pretty good with the choke out but only runs a couple of seconds after I push the choke in I took the carburetor apart and cleaned all the jets (everything actually looked pretty clean) but that didn’t seem to help
20 Jul 2026 11:17
Replied by Gr8uncleal on topic Choke problems
Sorry for asking, but "all the jets" included the pilot? They can be clean, but still be blocked.
20 Jul 2026 12:14
- Pap
Replied by Pap on topic Choke problems
Yep I took them out and blew air through all of them
20 Jul 2026 12:22
Could you see daylight through it?
20 Jul 2026 12:41
- Pap
Yep it’s definitely open when I push the choke in it runs a couple of seconds then dies like it ran out of gas
20 Jul 2026 13:13
- pabdt
Replied by pabdt on topic Choke problems
He asked if you could physically see daylight through the jet. Tricky little guys can trip you up every time. also, what are your float heights and is the
inlet valve functional.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- Swoop56
Replied by Swoop56 on topic Choke problems
you may have checked pilot jet was clear , but did you also check the passages
up to the venturi , ( there are two ) one straight up , and one on an angle exiting ahead of the slide .
20 Jul 2026 16:50
If you are able, give the carb a clean in an ultra sonic cleaner.
20 Jul 2026 23:39
- Pap
I can see daylight through all the holes I blew carb cleaner through air through and pushed a paint brush bristle through the pilot jet still no better
21 Jul 2026 09:08
