Exhausting Weight Loss Program
- Schu
Exhausting Weight Loss Program was created by Schu
Here’s a little bit of useless info for you…..
Every time I roast an exhaust pipe on an open fire they always seem noticeably lighter when I pick them out of the ashes the following day. I’ve always been curious as to exactly how much carbon and oily spooge has been burned away. So this time I weighed each pipe before and after with a handheld digital luggage scale. Here’s the before and after numbers.
GT80B was 6.20 lbs before and 5.78 lbs after for a loss of .42 lbs
DT125B was 9.62 lbs before and 9.30 after for a loss of .32 lbs
CT2 was 6.80 lbs before and 6.26 after for a loss of .54 lbs
DT400B was 9.74 lbs before and 9.28 after for a loss of .46 lbs
The CT2 pipe was plugged up to the point where it was really effecting its performance. I have sandblasted the pipes and today I will prime and spray them with VHT flameproof paint in flat black. I wish they offered a semi gloss in flameproof because I’m not a fan of flat black exhausts but I want to try this 2000 degree flameproof ceramic paint to see how well it holds up.
youtube.com/shorts/M6Tx7_8Urao?si=qa9na__1vxv542HG
The following user(s) Liked this Post: MarkT, swm, Snglsmkr, pabdt, Gr8uncleal, Ht1kid, thumperstew, Reed valve Richards
04 May 2026 07:21
- goatboy56
Replied by goatboy56 on topic Exhausting Weight Loss Program
Just did 3 (2 CT's and an AT) and wanted to see so weighted before and after and all lost about a half pound. What a difference in performance it made.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
The following user(s) Liked this Post: Snglsmkr, Schu, Ht1kid
04 May 2026 09:41
- Reed valve Richards
Replied by Reed valve Richards on topic Exhausting Weight Loss Program
That's pretty interesting, it's fun to burn out smoker pipes, I enjoyed doing mine, kills the mosquitos too
Yo Joe, Go Joe
07 May 2026 07:30
- nhsteve
Replied by nhsteve on topic Exhausting Weight Loss Program
Roasting your exhaust pipes over an open fire..............
There's a song in there somewhere SCHU!!!!!
"Exhaust pipes roasting on an open fire...
black smoke wafting in the air........"
The following user(s) Liked this Post: Schu, Ht1kid, pahiker
08 May 2026 06:51
- Mark350
Replied by Mark350 on topic Exhausting Weight Loss Program
Look at VHT Satin Clear 2000 degree (SP115) which will get you some sheen over the VHT flat. I did some headers a few years ago; sand based, washed down with acetone, light coat of VHT primer, flat black to just cover, cleared. I baked in a BBQ as per can directions. No peeling, holding up so far.
14 May 2026 18:45
