Eastwood Extreme Chassis Gloss Black Paint Test; BrandX Honda.
  • pabdt
  • pabdt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Was under orders to prepare wife's ride, 2003 TRX250EX.  Noting a rusty shifter, this is a great time to experiment w/the new Eastwood paint I'll be using on the CT1.  After removal of rust w/Vaporust, then some scuffing and cleaning with isopropyl alcohol, gave it 2 coats.
Painted light 1st coat, dried 24 hours, sprayed again a little heavier.   I am going to paint my CT1 frame w/this product, probably using a longer 1st coat dry time of 48-72 hours, depending on weather.   Thanks GFrench for the heads up on this paint and how to use it.
New fuel line, engine oil change, gear oil change, filter, battery, adjust choke linkage, dis and ultrasonic carb and a shifter repaint.  Its ready for summer.
This quad is ready for action.
was verifying choke function and attempting to get a fuel spray from the slide opening.  I need to try again on the later.
youtube.com/shorts/AJIYnbUze9Y?feature=share
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
The following user(s) Liked this Post: thumperstew
08 Mar 2026 16:43 #1
Eastwood paint products that I have used previously have usually stood up well. Your approach to prep and patience while drying is the way to go.
10 Mar 2026 15:20 #2
  • pabdt
  • Platinum Member
  • Platinum Member
It’s hard to do!  I’m used to acrylic urethane 15 min flash times.
old dog new trick
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
10 Mar 2026 15:34 #3
