DT1 piston question
- adguy2112
DT1 piston question was created by adguy2112
It’s been a while since I’ve posted. I’m doing a top end on my 70 DT1 and using partzilla for parts number confirmation before going on eBay. Found a first over piston in Canada using what I thought was a standard two ring piston number but I received a keystone type. Rings bought separately were regular first overs without expansion rings. I’ve, since, ordered a set of keystone rings. My question is about reading part numbers. The partzilla number description didn’t note as a keystone piston nor did the eBay post. Maybe what I received had the wrong piston in the box. Is there a better way to get accurate part numbers or read the part number format?
15 Feb 2026 07:35
- SKYDANCER46
Replied by SKYDANCER46 on topic DT1 piston question
Usually all the OEM Yamaha DT1 pistons that take keystone rings have a faint K marking to the right of the arrow marking on top of the piston. Sometimes you have to look carefully because the K is very light or 1/2 gone and it won't even look like a K.
1st over Yamaha piston (std style) is 214-11631-10
1st over Yamaha piston (keystone style ring) is 214-11631-11
1st over Yamaha piston ( keystone style ring) 214-11635-01-00
When i buy on e-bay i always ask the seller to send me good close up pictures of the tops of the piston and even ask them to check the ring grooves to see if there tapered or not. Some will check other don't know what i am talking about.
I also will use MC or Rocky brand complete piston kits as they come as a set and work well.
Replied by MarkT on topic DT1 piston question
Yes, there is a way to tell by the part number suffix for the early 214 prefix DT1 piston/rings.
"Square" ring Piston part number = 214-11631-xx
Suffix -00-96 = standard
Suffix -10 = first over
Suffix -20 = second over
"Keystone" ring Piston part number = 214-11631-xx (same base number!)
Suffix -01 = standard
Suffix -11 = first over
Suffix -21 = second over
"Square" Rings part number 214-11601-xx
Suffix -02 = standard
Suffix -12 = first over
Suffix -22 = second over
"Keystone" Rings part number 214-11601-xx (again same base number!)
Suffix -03 = standard
Suffix -13 = first over
Suffix -23 = second over
The "K" is marked on pistons and rings as Skydancer mentioned. If you have a "square ring" piston, you can easily install "keystone" rings accidentally (=bad!). "Square" rings won't fit into a "keystone" piston.
P.S. Yamaha superseded the "square" ring pistons to "keystone" type so the "keystone" ring pistons were shipped when they ran out of "square" ring pistons.
The following user(s) Liked this Post: RTD2, JayB, Snglsmkr, pabdt, Ht1kid, adguy2112
15 Feb 2026 09:28
- adguy2112
Replied by adguy2112 on topic DT1 piston question
Awesome description, Mark. So I reordered the correct first over rings to fit the keystone double ring piston. Would you know if a 214-11635-01 is a standard or keystone piston? What was in the box is definitely a keystone type but I was intending to pickup a square style. I’ll be returning the square ring set I originally bought but maybe this will help someone else in the future.
- adguy2112
Oh, I see sky dancer answered the question. All good. Thanks all
15 Feb 2026 17:20
I'm fairly certain Yamaha changed the numbers for the last year of the piston port models. 214-11635 was first over. 214-11636 was second over. Both are keystone and use the 214-11601-13 and 214-11601-23 rings respectively as far as I can tell..
One easy way to verify if piston has a keystone rings is to try to gently insert the ring into the groove "backwards". If groove is square, ring will easily slide right in all the way. If groove is keystone, it will only go into groove a tiny amount before stopping due to the taper of the groove.
Pic of what I mean by inserting ring "backwards" into groove. Piston is marked "K" so ring barely goes in "backwards". (Of course you need to make sure ring is right height for the groove or the test won't work)
The following user(s) Liked this Post: Swoop56, Snglsmkr, pabdt, adguy2112
15 Feb 2026 19:24
