60 CT1 3rd pinion gear.
- pabdt
60 CT1 3rd pinion gear. was created by pabdt
Not easy!..but got it off. Not sure if it was worth it. Now, will be unsure how well its attached once pressed back on. Ordered new 3rd pinion gear and a complete ready to go shaft w/gears. (have two engines, both have broken 3rd pinion). BTW, has anyone pressed one on and it worked successfully?
if anybody is interested, measurement/procedures are:
press off : 2nd (see pic below)
circlip: 5th
slide off: 3rd:
12.5mm shaft outside 2nd gear pinion to end of shaft
1mm between 3rd and 5th pinion.
Broken teeth 3rd pinion:
Setup to remove and install: (note, 1/8" angle iron started to bend, then gear slid off rather quickly. I had previouly heated it a bit w/torch)
circlip: 5th
slide off: 3rd:
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
Replied by MarkT on topic 60 CT1 3rd pinion gear.
RT325 has posted his experiences and tips about pressing 2nd gear on.
After working on large truck transmissions years ago and seeing how gears that aren't replaced in pairs often don't last very long, I've tended to buy complete good matched transmission sets on ebay. It didn't used to be hard to find one pretty darn cheap, as little as $20 + shipping for the whole transmission. Not sure what the market is like now?
And to qualify, the truck trans gears that "didn't last too long" was a comparison to using a new pair versus using one old and one new mating gear on transmissions that could last a million plus miles. And even the less optimal match of old and new gears still lasted many more miles than most of these old bikes will ever see.
The following user(s) Liked this Post: Snglsmkr, pabdt
23 Dec 2025 20:05
- Schu
Replied by Schu on topic 60 CT1 3rd pinion gear.
Flashback Enterprises on eBay has a few CT1 trans listed and they often accept reasonable offers. I bought a full transmission assembly for my JT project for $35 and they are only 15 minutes from where I work so I simply swing by and pickup my parts. (oh crap….I retired yesterday) Ok, it’s 45 minutes from my house.
They are a great bunch of guys over there. Check out their huge inventory and also checkout their motorcycles. I search their inventory by entering Yamaha in the search box and then I select lowest price. You can’t believe how many parts I’ve bought for $7.50 which seems to be their minimum opening bid. Kevin runs the eBay store, so if you make any offers, tell him Bill Schu referred you!
imgur.com/a/5UtBGQf
www.ebay.com/str/flashbackenterprisesinc
imgur.com/a/5UtBGQf
The following user(s) Liked this Post: MarkT, Snglsmkr, pabdt, Sneezles61
- pabdt
Replied by pabdt on topic 60 CT1 3rd pinion gear.
I have installed (successfully I hope) the new gear. I found a few measurement areas that were generally useful install.
BASIC INSTALL TECHNIQUE:
slide on 3rd pinion, 5th pinion w/circlip, press on 2nd pinion.
1. Freeze shaft, put nut on.
2. Heat 2nd pinion gear to 200F/93C.
3. Press on watching for the moment the 2nd gear pressed on pinion has ZERO clearance to 5th gear circlip. On the 2 shafts I have, both were installed this way from the factory.
4. Verify clearances and if desired test fit in case.
GENERAL CLEARANCES:
12.5mm from end of shaft
Zero clearance to circlip
22.25mm+ (gear wiggles) from inside of 5th to outside of 2nd.
If you measure before you disassemble yours, all measurements will be relative to your tool,and the ones
I would shoot for.
The clutch pulls the slack on the other side. This side simply "rides" the bearing. As a result, I say
make sure of zero clearance to circlip.
GENERAL CLEARANCES:
I would shoot for.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
