1970 Yamaha AT1. 125
- Lgleason
1970 Yamaha AT1. 125 was created by Lgleason
Good morning guys I’m having issues with the oil pump on my 1970 Yamaha AT1 125
I’ve done everything except the seal’s which are on their way. The white gear on the left will turn when I start the bike , I’m running pre mix right now , starts then stops intermittently. Will that stop once I get the pump resealed ? It’s bleeds fine and I’ve got no bubbles coming out. The oil just won’t come out of the pump at idle or full throttle .The top end was bad when I got the bike so I’ve boarded it and finally got the carb straightened out. She now runs like a champ. She’s been completely refurbished and looks amazing. Just need the oil pump straightened out and she’ll be done. Thanks so much everyone and Merry Christmas to all. Lew.
Replied by MarkT on topic 1970 Yamaha AT1. 125
Not that common to not have a pump fail like that.
First thing to look for is make sure the pin sticking out near the pulley is still there.
Second thought is maybe it's your expectations? How much oil are you expecting it to pump? At idle, the pump puts out a drop every few seconds. Even with pulley rotated to full throttle, it puts out only a few cc's every 200 pump strokes... pump drips oil, doesn't "gush".
Internals on pumps are tricky, if yours is bad, I'd send it to DEET to troubleshooting/repair.
23 Dec 2025 09:50
- Lgleason
Replied by Lgleason on topic 1970 Yamaha AT1. 125
I’d be thrilled with just a drop but not even that. I’m also aware of the 10 cc at full throttle for 200 turns. Like I said I can bleed it but that’s as far as it goes. From what I can tell all the pins are there. The seals are original so we will see. Is Deets the one who will rebuild them for 350 bucks ? Seem expensive to me. Thanks so much for your comments. Lew
23 Dec 2025 10:05
I haven't heard DEET's pump rebuild price in a while but I doubt it's anywhere near $350 unless maybe the pump needed a ton of work. Last price I remember wasn't much more than HVC Cycle charges for their rebuild kit. Well worth having someone that knows what to look for do it, especially if you have no output.
The only pump I ever had that didn't work had been "rebuilt" by the previous owner. There are some tiny little pins and springs that are easily lost and it is possible to assemble it incorrectly.
23 Dec 2025 11:54
Another thing you could check is remove the outlet port banjo bolt and check the check ball and spring underneath it. I have seen crud build up at the ball.
The following user(s) Liked this Post: Swoop56, nhsteve, Ht1kid
23 Dec 2025 11:57
- Lgleason
Hey Mark can you tell me how to get ahold of Deets ? Thank you.
25 Dec 2025 19:00
- Sneezles61
Replied by Sneezles61 on topic 1970 Yamaha AT1. 125
On this forum, DEET has replied and left his contact.
The following user(s) Liked this Post: Papawhellie
26 Dec 2025 07:55
- swm
Replied by swm on topic 1970 Yamaha AT1. 125
DEET's email: This email address is being protected from spambots. You need JavaScript enabled to view it.
Good luck!
Good luck!
26 Dec 2025 11:48
- nhsteve
Replied by nhsteve on topic 1970 Yamaha AT1. 125
I have had DEET rebuild a couple of pumps for me. With one of them he sent me a sticker with outputs for 125 and 175 cc bikes. This info is from that sticker.
"At maximum throttle and 200 strokes (turns of that white wheel) you should have a minimum of 4.65ml and a maximum of 5.15ml.
At minimum throttle you should have a minimum of 0.50ml and a maximum of 0.62ml."
My personal test setup to determine my output was this:
1.) Fix the throttle wide open mechanically somehow (I think I used tape around the throttle tube to the bars or lever).
2.) Get a small measuring cup (I used an old Nyquil medicine cup, which holds a little over 10cc and is graduated to see how much you get). Rig a wire holder for the cup so it catches the drops from the output line of the pump. Rig this so it is totally 'hands-free'.
3.) Rig the pump output line to the cylinder so that it will drip directly into the cup. 'Bleed' the line so you can see a drop of oil right at the end (that way you know the next drip goes into the cup). This needs to be rigged so it also is 'hands-free'.
4.) At this point the cup is clean and ready to catch the oil, the pump is held at maximum output, and you turn the white wheel on the pump itself 200 times (keep count by making marks on paper maybe so you don't lose count).
5.) If the pump output is correct, you should have about 5cc in that Nyquil cup for a 125/175cc, and about 10cc for a 250/360/400 (I believe that spec is from my 360A service manual)
Hope that is helpful.
The following user(s) Liked this Post: Schu, Sneezles61
02 Jan 2026 09:25
