74 DT360 jug replacement?
- dart451
Replied by dart451 on topic 74 DT360 jug replacement?
So, I finally had an opportunity to try to get the stud out of my original jug and it was a success! Due to the fact that the original drill out of the stud was off-set and not centered, (frame in the way), it made it quite difficult to work on. With the Jug off the engine, I was able to use a Hinge-drill tool to keep the drill centered. I then drilled both holes slightly larger to accept an 8mm tap...turned out pretty good! So now, I have ordered new rings and need to hone the cylinder...it's a standard 80mm bore so I believe I need a Flex-Hone tool, Aluminum Oxide 3.25"...does this sound about right? Not sure what grit I should order...
Replied by RT325 on topic 74 DT360 used jug installation
Luck & good management combined. You can do it.
19 Dec 2025 11:51
#12
- dart451
Seems that I'm starting to circle the drain here! I ordered a new set of piston (std) rings from Partzilla, got them today and there's no reason to open the box...they're approximately 2" diameter! So, does anyone know where I might find a new set of standard rings for my 74 DT360?? I can't seem to find anything...
24 Dec 2025 12:03
#13
Replied by MarkT on topic 74 DT360 jug replacement?
Partzilla doesn't show any rings for the DT360 as available and hasn't for years as far as I can remember. So not sure what you ordered?
Members Enduronut and DEET are worth a try.
Ebay has a couple of sets for sale 445-11610-00
(The -00 suffix is important on this part)
24 Dec 2025 16:15
#14
- dart451
Mark,
Thank you very much for your response! I think what I did was when I was searching for the rings, a link popped up for Partzilla and I ordered them without actually searching on Partzilla. I was able to find the correct STD rings on Ebay, hopefully I can get this project moving again once I receive the rings. Thanks again for your help!
24 Dec 2025 17:30
#15
Replied by Gr8uncleal on topic 74 DT360 jug replacement?
CMSNL in the Netherlands is always worth checking out for parts. They are currently showing all piston ring sets available, apart from 3rd oversize.
The following user(s) Liked this Post: MarkT, Snglsmkr, pabdt
24 Dec 2025 22:39
#16
- pabdt
Replied by pabdt on topic 74 DT360 jug replacement?
I had put Enduronut on speed dial lately…highly recommend him
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
The following user(s) Liked this Post: swm, Snglsmkr
25 Dec 2025 11:33
#17
- dart451
Hello again,
It's been awhile since I posted...I did manage to put new rings on the piston, honed jug well and my ring gaps were in spec. Put it all together finally yesterday. I tried to start the bike but it won't pop! I do have good spark! I also checked my compression and it only shows about 85 psi. Could it because of the compression release? Would I disable the cable to the compression release?? Any suggestions would be appreciated...thank you.
- pabdt
You would be surprised how much compression that valve releases. If you want to test it, compress the valve on head with hand and pull cable off.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
26 Jan 2026 12:36
#19
Remove the rubber protective boot from the decompression valve (on the front of the cylinder) and slide it a few inches up the cable and out of the way. Then, if it's not too difficult, disconnect the cable, noting first exactly how it should fit back.
26 Jan 2026 12:37
#20
