Restoring old hardened rubber
- 8ender
Restoring old hardened rubber was created by 8ender
Chasing a potentially bunk Youtube video I tried out ATP AT-205 on some hard rubber parts a few days ago. Parts were the bushings between the tank and frame, one seat rubber, one engine fin rubber, and the speedometer bushings. I initially poured the AT-250 into a plastic container, and then realized I'd made a terrible mistake as the AT-205 began to take apart the container, fogging the plastic and actually causing cracks. Into a glass jar it went.
After about 24 hours the rubber was actually rather supple and pliant again. I'm impressed. The AT-250 is a darker colour now. I feel like it might have lost a bit of it's magic eating the plastic container, but the rubber parts are still way better than they were before I put them in. No swelling, just more... rubbery.
Remains to be seen if they just harden up again but The Internet (unreliable at best) reports that since it's mainly a plasticiser most reports are that the rubber stays in good shape afterwards.
The following user(s) Liked this Post: MarkT, Snglsmkr, Ht1kid
Replied by Gr8uncleal on topic Restoring old hardened rubber
Is it AT-250, or AT-205?
11 Nov 2025 01:27
Replied by MarkT on topic Restoring old hardened rubber
I've used the ATP AT-205 in engines and transmissions of old cars with leaky seals and it's pretty amazing stuff.
11 Nov 2025 08:09
- 8ender
Replied by 8ender on topic Restoring old hardened rubber
Sorry yes, it's AT-205. I've chucked the hard front tank bushings in the jar as well as the turn signal flasher holder. It's looking brown and ugly in there and I still think the plastic did something to weaken the mixture. Might have to get another bottle for science.
Interestingly, I don't think it did much for the engine fin rubber damper I tried out. It's maybe... 20% softer than before after 24 hours. Either the mixture is weaker or that rubber is just too far gone from heat and vibration.
11 Nov 2025 20:27
Thanks for confirming.
11 Nov 2025 21:59
- 8ender
It did wonders to the turn signal flasher holder but barely anything to the tank rubbers. Seems like either the magic juice isn't as magic as before, or there's a rough correlation to how abused the rubber is (like the engine fin rubber) and how well it takes to the AT-205. Granted, nothing has sat in the jar longer than 24 hours because I'm impatient, so maybe it does better on harder rubber with time.
Also fair warning, this stuff eats paint. Make really sure your rubber is completely clean before reinstalling.
12 Nov 2025 22:19
- Bernhardo
Replied by Bernhardo on topic Restoring old hardened rubber
I had some old rubber tyres from a Meccano/Erector set that were pretty hard and brittle with cracks in them. I soaked them for a few days in brake fluid. They all came good, except for a couple that were too far gone. I also read that putting them in the dishwasher works too. So I threw them in there afterwards to clean up the brake fluid residue. Came out fine.
13 Nov 2025 12:54
13 Nov 2025 22:39
- automan
Replied by automan on topic Restoring old hardened rubber
Diethylene glycol monoethyl ether
14 Nov 2025 01:28
- 8ender
Update to this: For science, I tried a jar of 1/3rd Wintergreen oil and 2/3rds 99% Isopropyl alcohol as other wisdom on the internet says to try. This mixture worked better than the AT-205. After 24 hours even the hard fin rubbers were a bit softer. The seat stop rubbers were super plush and pliable.
Another note is that AT-205 treated rubber seems to "sweat" AT-205 for a day or so after treatment. This isn't great because it likes to eat paint.
I think my conclusion is that AT-205 is great for situations where you need to soften some rubber inside a working assembly like an engine or pump, where you need to mix it with another lubricant. You wouldn't want to dump Alcohol and Wintergreen in a working engine. I used a dropper to add some to my leaking autolube pump and it seems to have stopped the leak after a few days as an example. As a standalone rubber softener it works, but it's not quick, and you have to deal with the sweating chemicals for a few days after.
Wintergreen oil and alcohol works better for stray hard rubber parts like boots, bushings, etc. Dump them in, wait 24 or so hours, and they come out looking and feeling new. Even super crusty parts like my kickstart rubber came out like new.
Neither mixtures swell parts, but interestingly the AT-205 treated rubber pads under the seat did seem to return to their original form a bit. All of the pads had indents from the frame they sat on. The Wintergreen treated parts kept the indents, the AT-205 parts "healed" a bit. I think that's probably why it works so well inside engines and transmissions.
