1975 DT 250 Ignition System
  • pabdt
  • pabdt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
1975 DT 250 Ignition System was created by pabdt
Does the 74 - 78 all use the same ignition setup?  flywheel, points, condenser, coils, plate. etc?   I may have found a 75 bike, at least I think that is what it is.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
13 Oct 2025 01:06 #1
Replied by MarkT on topic 1975 DT 250 Ignition System
Not sure exactly what you are asking.  Generically, they are "magneto points ignition systems".
Specifically, they are NOT identical from year to year during that period, but you can make a "matched set" from a 77 work on a 75 for example by swapping all the components and adding a regulator.
(Alan probably knows for sure but I seem to remember 74-76 ignition was Hitachi and 77-78 was Mitsubishi)
The following user(s) Liked this Post: Snglsmkr, pabdt
Last edit: 13 Oct 2025 08:27 by MarkT.
13 Oct 2025 08:25 #2
Replied by Gr8uncleal on topic 1975 DT 250 Ignition System
Part numbers suggest that all models use Mitsubishi parts (ie the part numbers end -2...).
I would bow to Mark's far greater knowledge and experience on whether or not complete setups can be interchanged - I don't know the clearances needed for the inside of the points cover, how long the end of the crankshaft is, or the wiring/terminals arrangement.
The following user(s) Liked this Post: MarkT, Snglsmkr, pabdt
13 Oct 2025 08:39 #3
74-79 250/360/400had a smaller opening in the case and a slightly smaller flywheel than the 68-73 250/360.
Physically, the 74-79 systems fit 68-79 for the 250/360/400.
The 68-73 250/360 will usually not fit the 74-79 because of the slightly bigger flywheel OD.
Output power and wiring changed slightly as the bikes got newer but wiring can be adapted fairly easily to work if you swap complete systems (ie you need to swap the stator and flywheel as a matched set.)
The following user(s) Liked this Post: Snglsmkr, pabdt, Gr8uncleal, Schu
13 Oct 2025 17:17 #4
