Improper but effective
  • Schu
  • Schu's Avatar Topic Author
Improper but effective was created by Schu
Put new fork seals in my 360 today and I found a safe way to use my RevZilla seal remover. My previous attempt with this tool on my 250 left me with a cracked lower. Ugh!
So this time I disassembled the pry hook from the handle and slipped some large flat washers over the stem of the handle and then reassembled the pry hook. Then I used the perfectly shaped pry hooks simply as a hook. No Pry!
Each whack of the hammer moved the seal ever so slightly without inducing any forces against the opposing wall. Redneck slide hammer!
The following user(s) Liked this Post: JayB, AirborneSilva, Ht1kid
Last edit: 16 Aug 2024 14:48 by Schu.
16 Aug 2024 14:28 #1
Replied by JayB on topic Improper but effective
Schu, Nice!
I did something different with the same type of tool.  I ground it down so when using it I was pushing straight down on the opposite side while prying up.  I used a wood shim on top of the aluminum and pried and prayed!  It worked but I like your method better.  Maybe I could post a picture next time I replace fork seals.
16 Aug 2024 18:25 #2
Replied by AirborneSilva on topic Improper but effective
Good idea! I've been putting off putting seals in my DT400's forks because I was not looking forward to doing this. Thanks for the video...
17 Aug 2024 09:07 #3
