XS750 clutch plates compatibility with 250 and 360 Enduros.
  • pahiker
  • pahiker's Avatar Topic Author
I found the below on a facebook post, can anyone validate if this is true?
Yamaha XS750 (77-79) clutch plates have the same outside dimensions as the DT 250 and RT 360 bikes but the friction surface is wider on the XS parts. I confirmed that they function well in my '70 RT1. I just had to eliminate the rubber o-rings in the clutch pack and they dropped in. If anyone is looking for a cheap clutch upgrade, these work great and are widely available. The part number is 4H7-16321-02-00. I can also confirm that the XS clutch springs do NOT fit as they're too large, so don't bother with those.
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
05 Aug 2024 11:45 #1
Wow, great to have info like this. If they're wider did you have to run one less fiber or still all fitted up nicely. Thanks for posting info.
ps, don't do what i did haha to fit plates with a slightly bigger outer edge but the ears all lined up. Not sure what they were off, maybe my 465 from wayback. Still waiting for the basket fingers to fall off but it's had a fair beating since.
photos.app.goo.gl/LiCkXd6WFx1yowbm7
Last edit: 05 Aug 2024 16:54 by RT325.
05 Aug 2024 16:49 #2
  • pahiker
RT325: I didn't do this, I found this post on Facebook and asked if anyone on this forum could validate the plates fit.
1973 Yamaha RT3
2024 Suzuki DR650
06 Aug 2024 03:06 #3
Oh, Ok, thought you'd fitted them. Hope someone puts us right as sounds like a good plan if they fit. Cheers.
06 Aug 2024 14:09 #4
Doesn't surprise me at all.  Several Yamahas take the same basic discs and if you get rid of the goofy rubber rings you can use ones with wider friction surface.  I've used the IT175 discs in the later DT175.
06 Aug 2024 17:14 #5
Looks like i was mistaking "wider" for thicker in post #2.
I'm on the right planet now [third from the sun] haha.
So more surface area on each pad leaving 'no room for those pesky rubbers. Cool.
06 Aug 2024 17:24 #6
