Different Air filters from stock?
  • Scottish lad
  • Scottish lad's Avatar Topic Author
Different Air filters from stock? was created by Scottish lad
So I’ve just took ownership of a 84 XT600 43f also bought a Haynes Manuel for it and the air filters are different could well be at sometime in its life someone has changed it, So there is no air box as such but 2 separate round air filters with 2 piece foam on each, and there is a separate small cone shaped metal type filter with a hose going down to the crank case is this normal.
Scottish Lad
07 Jul 2024 11:51 #1
Replied by MarkT on topic Different Air filters from stock?
Parts list diagrams are online as a double-check...
Sounds like someone replaced the stock airbox with "pod" filters and installed a crankcase vent filter (necessary because crankcase vent probably originally connected to stock airbox, which is now probably buried in a landfill someplace)
As far as a "normal"?  I don't think anyone can answer that?  Since the filter elements are still available from Yamaha, it doesn't seem like a "necessary" modification.
The following user(s) Liked this Post: Scottish lad
07 Jul 2024 13:17 #2
Replied by RT325 on topic Different Air filters from stock?
Probably just thought it would breath better like that being a twin carbs on a single cylinder. I guess not a bad thing except for inlet noise which some people might think sounds quite grunty & powerful. Just keep the filters lightly oiled if you go near anything like dust. Crankcase breather filter probably gets a breath of oil mist but keep an eye on it I case it's totally dry & could draw dust in as don't think it has a one way valve thingy further down in.
The following user(s) Liked this Post: MarkT, Scottish lad
Last edit: 07 Jul 2024 13:49 by RT325.
07 Jul 2024 13:48 #3
