Front mudguard
- Fozzy500
Front mudguard was created by Fozzy500
Hi. Does anyone have a recommendation for a replacement front mudguard for the CT range which can use the original lower fork mounting please? TIA.
04 Apr 2024 11:58
Replied by Gr8uncleal on topic Front mudguard
I'm assuming that you can't find an original, or those that are available are too expensive?
As the mounting brackets and mudguards are separate items you could, in theory, mix and match whatever you can lay your hands on, although some fabrication will be needed. Or were you looking for an alternative that bolts straight on?
04 Apr 2024 23:36
- Fozzy500
Replied by Fozzy500 on topic Front mudguard
The bike (CT1C so steel fork legs) came to me with an ugly bit of plastic U-bolted to the bottom yoke so that was binned. An original replacement would be great but yes rare in UK and expensive. I don't need originality for this bike so just looking for an alternative or universal part that could be made to fit and that doesn't look too stupid. Just wondered if anyone had any experience to hand down. Cheers
05 Apr 2024 01:10
Yes, sellers are taking the pith on prices and likewise USPS on postal costs.
05 Apr 2024 02:56
- Sneezles61
Replied by Sneezles61 on topic Front mudguard
Doesn’t Harley Davidson still make some steel fenders?
Sneezles61
Sneezles61
05 Apr 2024 05:09
Message just sent.
The following user(s) Liked this Post: Fozzy500
10 Apr 2024 01:14
- Tinkicker
Replied by Tinkicker on topic Front mudguard
Back in the day when I competed at trials, if the original fender mounts got mangled as I did yet another flying W after " failing to negotiate" a nest of boulders, I used to cut and bend a new bracket from 2mm alloy sheet and drill to fit the forks.
Then rivet something like this to it:
10 Apr 2024 01:45
