Bassani exhaust pipe
- Dennis D
Bassani exhaust pipe was created by Dennis D
Anyone running a Bassani pipe on their 71-73 CT that could send me a picture of the mounting?
22 Mar 2024 12:07
Replied by Gr8uncleal on topic Bassani exhaust pipe
I don't have any photos of the one that was fitted to my own 1971 CT1C when I bought the bike, bit it was mounted to the top shock absorber bolt.
If you have a 1972 (CT2) or 1973 (CT3) bike, I think you'll need the special CT1 top shock absorber bolt to enable you to fit it.
Edit - the special bolt is the longer of the one shown in the photos in this link (I sold the parts a while back).
Yamaha top shock mount bolt AT1 CT1 248-22241 90116-10116 261-22242 90116-10115 | eBay
- Schu
Replied by Schu on topic Bassani exhaust pipe
This isn’t a CT, but it is a Bassani mounted on my DT125B. If you zoom in you will see that I had to buy a universal muffler bracket to fit the outlet diameter. Then I used a Yamaha rubber insulated exhaust hanger that I had in my spare parts bin.
imgur.com/a/LTKu2GL
imgur.com/a/R23YFJL
imgur.com/a/LTKu2GL
imgur.com/a/R23YFJL
- Dennis D
Replied by Dennis D on topic Bassani exhaust pipe
Thanks for the pic. Header on the pipe I have is quite a bit different.
I may have to fab something up to make it fit. Understand about the
bolt as I am going to put one on a 71 CT and another on a 73 CT. Does
that exhaust on your bike set lower that the stock pipe did? Hard to tell
from the angle.
from the angle.
22 Mar 2024 13:07
- Schu
Yes it does sit lower. I actually made up a filler panel to block off the view between the top of the pipe and the bottom of the seat because you could see into the void under the seat and I just didn’t like it.
imgur.com/a/U3yBIwB
oops. Wrong link first time.
imgur.com/a/U3yBIwB
- Dennis D
LOL! Someone who is as anal as I am it seems.
I think I might use the header off of a Yamaha pipe
that I have and get it to sit where I want it to. This
pipe supposedly came off of a AT3, but it crashes
into everything. I am going to run it and keep my
rear turn signals!
rear turn signals!
22 Mar 2024 13:32
