What might this noise be
  • Tunnie
  • Tunnie's Avatar Topic Author
What might this noise be was created by Tunnie
Hello, my Dt 100 is making a noise that I’m not sure what it means. The bike runs well and starts well. The noise is not affected by engine speed, it started after I changed the crank seals. I did have a bit of bother getting the clutch side off. Please don’t laugh but it sounds like blub blub blub blub with a rise in tone that repeats. What might this be? best wishes Tunnie.
25 Feb 2024 09:35 #1
Replied by Schu on topic What might this noise be
Try uploading a video to YouTube and then post a link to the video. That way we can hear what you are hearing.
25 Feb 2024 09:52 #2
Replied by Tinkicker on topic What might this noise be
If it started after you changed the crank seals, there is where to suspect first.  If the clutch side is blowing, the noise could conceivably be coming from the transmission breather pipe?
25 Feb 2024 09:55 #3
  • Tunnie
Replied by Tunnie on topic What might this noise be
Thanks for replies will try to get the video
25 Feb 2024 10:19 #4
  • Tunnie
Don’t want to sound too stupid but should you be able to blow or suck through the breather pipe or does it have some sort of valve on a Dt 100
29 Feb 2024 06:53 #5
Replied by MarkT on topic What might this noise be
No valve in the transmission breather hose.  I have come across plugged hoses.
29 Feb 2024 08:43 #6
