Common circuit (Brown Wire) Question
  • WyoDan
  • WyoDan's Avatar Topic Author
Common circuit (Brown Wire) Question was created by WyoDan
What should the brown (common circuit) wire behind the headlight be plugged into? It's a female connector coming from the main body of the wiring harness. Bike is a 1971 DT1 250  I can't tell from the wiring diagram.
A photo would be nice. I can also email you a photo of what I'm referring to if possible. Couldn't get one to attach here.
26 Dec 2023 14:04 #1
Replied by Tinkicker on topic Common circuit (Brown Wire) Question
Brown is switched live. It feeds everything when the ignition is switched on.
26 Dec 2023 16:13 #2
Replied by MarkT on topic Common circuit (Brown Wire) Question
Female spade or female bullet connector?
If spade, probably goes to the horn. There would be a pink wire nearby.
26 Dec 2023 18:33 #3
  • WyoDan
Replied by WyoDan on topic Common circuit (Brown Wire) Question
Yeah I did figure that out. Just nothing apparant and obvious that it plugs into. IE no brown male ends to plug to.
26 Dec 2023 21:16 #4
  • WyoDan
Female bullet. Horn is separate and working. It is pink though!
26 Dec 2023 21:17 #5
Replied by Gr8uncleal on topic Common circuit (Brown Wire) Question
Front brake light switch - see link below. You should have a green/yellow wire with a female bullet connector in there as well.
   FRONT STOP SWITCH ASSY for DT1E 1971 USA - order at CMSNL
27 Dec 2023 01:20 #6
  • WyoDan
You are the man! Thanks Gr8uncleal!
27 Dec 2023 12:07 #7
