Kick start axle stop gouging case interior.
- Bdee
Kick start axle stop gouging case interior. was created by Bdee
Noticed the kick start would sometimes not spring back and got caught up near the pegs.
Removed the case cover and the kick assembly and saw that the stop has been wearing the case away.
Has this happened to others? What would you recommended to handle this?
google photos album
google photos album
11 Dec 2023 15:10
Replied by RT325 on topic Kick start axle stop gouging case interior.
Not sure what to make of that as its 'way around' from where the stop on the shaft should get to. Might be wrong.
Shape of the curl wear mark looks like idler gear but can't be as it isn't the large.
That'll get people thinking.
Is the shaft stop broken?.
Still can't see how that would cause anything like that.
- mike8162
Replied by mike8162 on topic Kick start axle stop gouging case interior.
I had this problem with my CT3. I bought a new kick axle off ebay and it solved the problem. My understanding is that the kick starter will be allowed to snap back occasionally over the life of the bike. Over time the pressed on lever will move and then it is clocked wrong. I would guess that it can be rotated back but I didn't know how far I had to go to be correct so I just bought a new one.
Cheers
Cheers
11 Dec 2023 16:37
- Bdee
Replied by Bdee on topic Kick start axle stop gouging case interior.
Dam, both of you just blew my mind. I just had it installed incorrectly. fudge
and thanks!
and thanks!
11 Dec 2023 17:00
I might be wrong but thought the worst that could happen if the stop broke loose was the kick lever goes forward & hits the cover so you then correct it but does it again until multiples of correcting & the spring tension is lost so won't return. Can we have a pic of your kick shaft & gear with bits n pieces, springy clip etc.
11 Dec 2023 18:42
