Speedo issue
- Fozzy500
Speedo issue was created by Fozzy500
Hi all.
The needle in the speedo of my CT3 seems to be linked directly to the cable!
So when the wheel turns forward the needle goes all the way up and when the wheel turns back the needle comes back down....
I'm not sure how these instruments work - is this something that could be freed off or is it just broke and needs a full rebuild?
See video imgur.com/a/9210kLD
Appreciate any help on this one.
Thanks!
Thanks!
18 Nov 2023 04:03
- Tinkicker
Replied by Tinkicker on topic Speedo issue
There is usually a magnet that spins inside a drum. In general terms.. As the magnet spins faster, the magnetism draws the drum more powerfully against a spring and the movement of the drum turns the needle.
If the drum is binding against the magnet, it will cause what you describe.
- Fozzy500
Replied by Fozzy500 on topic Speedo issue
OK great, thanks for that, so it will need a rebuild.
Cheers.
Cheers.
18 Nov 2023 10:57
- automan
Replied by automan on topic Speedo issue
Most likely debris.
Piece of something between the permanent magnet and the aluminum cage.
They work on eddy current. Faster=stronger attraction.
cliff
cliff
- Fozzy500
Further investigation shows that the central boss that the cable fits to is loose and is being pulled back by the cable putting the drum/magnet out of line I guess. When I push it forward a little the speedo works normally.
The visible screws on the bottom of the instrument are not loose.
19 Nov 2023 15:22
