69 dt1 Fork cap bolt air valve
  • pmb
  • pmb's Avatar Topic Author
69 dt1 Fork cap bolt air valve was created by pmb
Hello everyone.  I am in the middle of rebuilding the forks on a 69’ DT1B 250. I read a thread about a problem another guy had and that was very helpful. However, I ran into a small snag as I was cleaning everything up. The cap bolts on the forks have an air valve to allow air in or out as an adjustment to the stiffness of the fork… I figured I should verify that the valve actually works. After removing the big phillips screw I found a spring with a little rubber bumper and the tiny pin that sticks up through the cap bolt. No surprise that the little rubber bumper basically disintegrated when I touched it. I figured I could make a new rubber bumper with a bit of rubber and an exacto knife. Upon further inspection that little rubber bit must have a very particular shape to actually fit and do the job. I did a search on this subject and didn’t find anything that helped.
So, here’s my question.
Has anyone just drilled and tapped it for a schradar valve? Is that possible?
Anyone have any ideas or suggestions for how to repair the valve without having to try and get replacement parts that are made from un-obtainium?
It seems like such a small problem but I don’t want to put the forks back together until I solve this issue.
Thanks in advance for any assistance.
pmb.
17 Oct 2023 15:51 #1
Replied by DEET on topic 69 dt1 Fork cap bolt air valve
I have rebuild kits for them.
if you just want the ball, I have those.
The following user(s) Liked this Post: MarkT, swm, Swoop56, Ht1kid
17 Oct 2023 16:00 #2
  • pmb
Replied by pmb on topic 69 dt1 Fork cap bolt air valve
Well then, I feel the fool for thinking that would be an impossible find. I actually messed around with it a bit more and got it to work with my cut down bit of rubber but I would confirm that I am a fool if I don’t take advantage of your rebuild kit.
Thanks. I will be moving on to your site to order two of them.
I absolutely love this site!!!
17 Oct 2023 16:14 #3
