DT175B project re-initiated!
  • Makotosun
  • Makotosun's Avatar Topic Author
  • Administrator
  • Administrator
Replied by Makotosun on topic DT175B project re-initiated!
Whew - done with outer cases.
Before;
After:
It’s not perfect, it’s a rider ;)
07 Jul 2019 21:21 #61
  • Makotosun
  • Administrator
  • Administrator
About done for today.
I just finished new front fork seals, clean and reassembled the forks (will add oil tomorrow when I have better light.
So now it’s basically detail the motor, install the swing arm and forks, figure out the re-pop Taiwan wiring harness (it appears correct and decent though not DEET!), new cables, controls and decide what gauges to go with!
Probably going to be a rider by next weekend if not completely finished.
This will be a record build time for me!
The following user(s) Liked this Post: Badger52
07 Jul 2019 22:52 #62
  • Makotosun
  • Administrator
  • Administrator
Finally getting to the fun part!
It’s now a roller.
Lots of new nuts & bolts, some fresh grommets, large bucket of elbow grease. New Tusk Aluminum bars.
Who knew that Amazon would have the best price on a fresh new sprocket!
The motor still in detail stage, fenders getting fresh paint. It could be a rider this weekend, though I’ll probably wait and do all the street wiring while it’s opened up!
12 Jul 2019 18:55 #63
  • Makotosun
  • Administrator
  • Administrator
Stayed up late last night, locating bits and pieces and formulating on last dealer order.
Definitely making progress. It has fenders, a kickstand, and today if things go well, possibly even a motor. Be awhile for a ride still, as I need to figure out the full wiring stuff.
13 Jul 2019 08:34 #64
  • Makotosun
  • Administrator
  • Administrator
NLA footpeg return springs MIA. What to do?
Well the peg itself is the same as the DT400B though the mount is different. Problem is they don’t make those springs either.
I stumbled across a set of UK repops for my various DT400 projects and decided to see . . .
These are not an exact fit, but work, and fit pretty well. I could probably massage for a better fit but the seem good.
Gonna have to replenish my inventory!!
www.tytrials.co.uk/trailandtrialsuk/prod...TY250-Twinshock.html
13 Jul 2019 09:01 #65
  • Makotosun
  • Administrator
  • Administrator
Progress continues:
13 Jul 2019 20:37 #66
  • Makotosun
  • Administrator
  • Administrator
And a couple more:
Been a busy day!
The following user(s) Liked this Post: MarkT, Steve F, Badger52, JayB, Midlife Motor
13 Jul 2019 20:39 #67
  • Makotosun
  • Administrator
  • Administrator
On my repainted OEM throttle housing, the screw that holds the kill switch on was rusted bad. It’s a tiny bigger and not even listed on the parts diagrams. I found a solution at Hole Depot:
A #4 screw is correct in diameter, but these were a bit long. So I cut one down to length, and Voila!
I carefully masked the label before painting - turned out pretty good. For comparison, here is the other side Chinese re pop:
Now I just need some more in-committed free time . . .
16 Jul 2019 21:08 #68
  • Makotosun
  • Administrator
  • Administrator
Super busy weekend so not much progress. Carb didn’t need a soak, so just a quick carb cleaning rinse, then something I learned this year from Lee Fabry - Eagle Mag Cleaner on the carb.
It has some acidic content you can smell. Sit maybe 15 min after spraying. Then another carb spray rinse, and it’s looking back fresh.
29 Jul 2019 07:03 #69
  • Makotosun
  • Administrator
  • Administrator
Once again, DEET to the rescue! 1975 DT175B getting a facelift! (The new one has the number correctly, just obscured for the posting! Contact him directly for your own!
30 Jul 2019 18:18 #70
