installing new seat cover
- AirborneSilva
Replied by AirborneSilva on topic installing new seat cover
thanks, I will give pulling the cord tight a try, it does make sense!
20 Jul 2023 12:47
#21
Replied by Gr8uncleal on topic installing new seat cover
I recall my upholster saying that my cord had either gone, or was on the point of going, so he replaced it with some curtain cord, or suchlike, and pulled this tight at the rear of the seat.
20 Jul 2023 13:51
#22
- AirborneSilva
Mine has the cord coming out of the front, I did a test pull on one of them (with seat on bike), had to use pliers since it was just slipping between my fingers but it did straighten it out a bit. I think I need to take the seat off then apply a little bit of heat with the heat gun and give them a pull...
The following user(s) Liked this Post: Ht1kid, Pedalcrazy, Sneezles61
20 Jul 2023 14:38
#23
- Pedalcrazy
Replied by Pedalcrazy on topic installing new seat cover
Yes if clips are crimped down the cord may not pull or will pull really hard.
22 Jul 2023 06:26
#24
- AirborneSilva
Ok, I'll open them up a little. Thank you!
22 Jul 2023 07:00
#25
- jez
Replied by jez on topic installing new seat cover
Hi Fellas, i have done a few seat covers and found this method makes the job easier. use the wood as a prop to compress the seat foam while you fit the cover . keeps the seat still and gives you an extra hand . good luck
25 Jul 2023 07:55
#26
- AirborneSilva
Thanks Jez
25 Jul 2023 08:44
#27
- AirborneSilva
You're right trailboss, I didn't glue the foam down.
26 Jul 2023 12:48
#28
I would imagine that glue is a last resort.
26 Jul 2023 13:23
#29
- AirborneSilva
I still haven't gotten around to taking the seat back off so I can release some tension on the clips then I'll apply a little heat so soften things up and give a pull on the cords, the one I did pull on a bit with the seat on looks better so I think I'll be good. As for gluing down the foam, that just doesn't make sense to me and I had no problem pulling the cover over it.
26 Jul 2023 15:08
#30
