Ct3 repair
- Barrya
Ct3 repair was created by Barrya
Hello i have broken my ct3...it started with a kickstart problem thats broken the cogs around it....i live in sheffield can anyone recomend someone who can repair these old bikes....i am not mechanically gifted thanks barry.
30 Jun 2023 00:17
Replied by RT325 on topic Ct3 repair
Welcome from NZ.
If you weren't half a world away i'd be 'into it'.
Sounds like you're in there & looking so is it possible to link a few pics via an external link thingy like Imgur seeing the site one is out of action.
Someone from your side of the world will be along soon i think.
I have an AT1 that thinks its a CT3 with a later 175 top end.
The following user(s) Liked this Post: MarkT, Barrya
30 Jun 2023 01:49
Replied by Ht1kid on topic Ct3 repair
Greetings from Tennessee.
Have you taken the clutch cover off to confirm if so pictures would help us get you back on the road
The following user(s) Liked this Post: Barrya
- Tinkicker
Replied by Tinkicker on topic Ct3 repair
Greetings from the UK.
Have you actually got the cover off and seen the broken gears with your own eyes?
If so pics of the gears and the inner end of the kickstart shaft would be helpful.
If you are just assuming that the gears have stripped because the kickstart is not engaging or only engages sometimes, that could be a much simpler and less expensive repair.
- Barrya
Replied by Barrya on topic Ct3 repair
Thanks for the replies i took it to a local shop....3 gears are damaged...kickstart,kickstart idle and kick clutch pinion...all parts ordered...hopefully should be ok but mechanic said he had never seen this before so not sure what has caused it ...barry
01 Jul 2023 13:50
Replied by MarkT on topic Ct3 repair
Did gear behind clutch basket break in two? That happens sometimes.
01 Jul 2023 13:57
