Inherited Enduro 1975 DT125B
Replied by Gr8uncleal on topic Inherited Enduro 1975 DT125B
Did you see my previous question about checking that you used oil suitable for a wet clutch (and apologies if you've already checked and answered this!)?
25 Jul 2023 00:29
#181
- rfisher125
Replied by rfisher125 on topic Inherited Enduro 1975 DT125B
Response to questions:
- Regarding the oil, this is what we used drive.google.com/file/d/1LTJlCG-28jm2eGj...pq6/view?usp=sharing
- My daughter noticed no difference (better or worse) after making the 2nd clutch adjustment
25 Jul 2023 05:26
#182
Replied by MarkT on topic Inherited Enduro 1975 DT125B
I'm wondering about the adjustment too... doing the adjustment correctly seems to be hard for some reason. It could just be the plates are toast though.
25 Jul 2023 05:56
#183
- Tom P
Replied by Tom P on topic Inherited Enduro 1975 DT125B
My '71 CT1 only had around 360 miles on it when I began working on it. The clutch was stuck, and was slipping fairly badly after getting it unstuck. I ordered new friction discs, and even with only 360 miles, the old disks did measure under spec. I ordered aftermarket discs that only cost around $14 shipped, but next time I would get Yamaha discs. These slip a bit when cold, but after warming up are fine. I'd also rough up the steel discs with sandpaper next time. I did remove the rubber damper rings, as many here suggest. It's not a hard job, but like most, is harder the first time.
25 Jul 2023 08:18
#184
It's impossible to know if someone has been into the clutch... in any case it's prudent to TAKE PICTURES as you disassemble. The exploded parts diagrams are not reliable assembly diagrams. Many clutches have been assembled incorrectly. If you post the pictures, someone here can tell you if it was assembled correctly.
P.S. I leave the rubber rings out as well. I've had them cause issues with slipping. I've never had a problem caused by leaving them out.
25 Jul 2023 08:26
#185
- rfisher125
This the correct part (5 of them)?
Yamaha 3HA-16321-00-00 - FRICTION PLATE | Partzilla.com
26 Jul 2023 05:26
#186
Replied by Ht1kid on topic Inherited Enduro 1975 DT125B
Yes 5 of them
26 Jul 2023 07:07
#187
- rfisher125
Life's been a bit crazy as of late, so haven't been able to post. Anyway, we had an experienced rider take it for a spin. It ran great! He had no problems shifting and accelerating. The only issue he mentioned was a tight throttle (not sure what that means...any ideas?). Good to know the clutch might be ok...just rider inexperience
. My daughter has been practicing this past week...learning how to shift the gears.
I think the one maintenance item we've yet to tackle is to confirm the oil pump is functioning correctly. I've found a few YouTube videos...but any other tips?
20 Aug 2023 07:50
#188
- Tom P
My CT-1 throttle was sticking a bit, and it turned out the end of the handlebar was rubbing the grip. I just moved it outboard a bit, and that freed it up.
20 Aug 2023 09:12
#189
- 1960yblock
Replied by 1960yblock on topic Inherited Enduro 1975 DT125B
This has been a very interesting read as I am currently working on the exact same bike that I bought at a farm sale in Colorado last spring. Mine has about 2800 miles but is not nearly as pristine. Right now my issue is that the oil line from the pump to the carb was very brittle outside the pump housing and broke removing it from the carb. my question is, how do you remove the oil line from the oil pump, and replace it with new?
02 Apr 2024 13:07
#190
