Genuine Yamaha or Quality Replacement. Is There A Difference in Performance?
- Tinkicker
Genuine Yamaha or Quality Replacement. Is There A Difference in Performance? was created by Tinkicker
Appropos my two stroke paranoia thread. I have been clutching at straws on that one, including searching for possible misalignment problems.
So is a good quality replacement from a trusted source as good or better than genuine?
During my DT175 rebuild, I bought and fitted a TKRJ piston and small end bearing. These were supplied by a very well known and respected UK aftermarket Yamaha parts supplier.
TKRJ are a quality japanese made piston and are allegedly fitted as OEM to some makes. I have fitted dozens of them without problems, others from the likes of Mitaka and ProX also. I would never fit a cheapo £20 ebay chinese special however.
As I stripped out my ailing DT cylinder, I noticed something I did not like at all. Excessive small end bearing float. It had migrated to the left a considerable amount. Was this correct? Was this causing misalignment and all my cylinder wear problems?
I resolved to fit all new genuine parts this time around and bought a genuine NOS Std piston, new genuine rings, circlips, pin and small end at a cost three times the price of aftermarket. Was it worth it?
Parts arrived this morning. Time to compare side by side.
Pic one. TKRJ piston with aftermarket little end bearing. End float between pin bosses around 6 -7mm.
Pic two. Genuine piston and genuine little end bearing. End float between bosses 1 - 2 mm. Ignore the missus's reading glasses, it seems they are hell bent on getting into all my pics today.
The genuine bearing is about 1mm wider than the aftermarket. It is the width between the piston pin bosses that make the most difference.
So it seems that you cannot beat genuine parts. While that end float is not the full story of my problems, it is certainly not to design spec.
Replied by MarkT on topic Genuine Yamaha or Quality Replacement. Is There A Difference in Performance?
Probably a 125 bearing. They are narrower.
29 Apr 2023 05:45
Replied by RT325 on topic Genuine Yamaha or Quality Replacement. Is There A Difference in Performance?
Looks to be a lot more rollers in the first pic. Albeit a shorter 125 cage. Are they longer rollers too, or just an illusion.
01 May 2023 01:36
- Tinkicker
Replied by Tinkicker on topic Genuine Yamaha or Quality Replacement. Is There A Difference in Performance?
Longer rollers. Overall, the cage width on the pattern part was 1mm narrower than the genuine one.
The big difference was the spacing between the pin bosses on the pistons. It was quite a surprise to see.
03 May 2023 08:34
