AT1 Ignition wiring harness
  • htw123hotmail
  • htw123hotmail's Avatar Topic Author
AT1 Ignition wiring harness was created by htw123hotmail
got a NOS ignition switch with keys for my 70 AT1 but the wiring harness for the bike has a male connector as does the wiring for the switch. I see the original switch was supposed to have a female connector. Any thoughts on how to make this work (both are 3 wire, same connector) without cutting the wires? Maybe there is an adapter available or some way I can make something?
03 Mar 2023 19:51 #1
Replied by Ht1kid on topic AT1 Ignition wiring harness
Vintage connections sells the plastic connections I’ve got two AT nos wiring harnesses I can double check it if you want me to or post a picture of your switch
03 Mar 2023 21:31 #2
Replied by Gr8uncleal on topic AT1 Ignition wiring harness
Yes, photos would be useful.
You might have a 1971 AT1C (even though the plate on the frame might say manufacture date of 1971). See links below to CMSNL photos of the 1969 and 1970 switches.
MAIN SWITCH ASSEMBLY for AT1B 1970 USA - order at CMSNL
MAIN SWITCH ASSEMBLY for AT1C 1971 USA - order at CMSNL
As Ht1kid says, you can likely get the parts you need from Vintage Connections, either to make a link with females at both ends, or to correct the error on your switch. When buying the narrow spade connectors, male or female, make sure that they have the retaining 'tangs' on the underside.
04 Mar 2023 00:25 #3
  • htw123hotmail
Replied by htw123hotmail on topic AT1 Ignition wiring harness
Thanks, I think building a new connector is the way to go.
04 Mar 2023 08:19 #4
  • htw123hotmail
thanks!
04 Mar 2023 08:19 #5
