Wasted cash on bad brakes
  • msavitt
  • msavitt's Avatar Topic Author
Wasted cash on bad brakes was created by msavitt
I just tossed 3rd set of banana peel brake shoes in the trash.
The only ones I’ve found that are any good - and I am sure there are more - are Yamaha genuine, EBC, Ferodo.
Ones I’ve had to toss into trash for self preservation include celox and 2fastmoto.
The following user(s) Liked this Post: Enduronut, AirborneSilva, Ht1kid
22 Feb 2023 00:51 #1
Replied by Tom P on topic Wasted cash on bad brakes
I've got a set of 2FastMoto on my CT-1 front, and they're working fine. What problem were you having?
22 Feb 2023 11:29 #2
Replied by SKYDANCER46 on topic Wasted cash on bad brakes
I only use genuine Yamaha shoes on front and Yamaha or Vesrah for the rears. I won't use the Vesrah on front. No luck with others.
Last edit: 22 Feb 2023 12:27 by SKYDANCER46.
22 Feb 2023 11:36 #3
  • msavitt
Replied by msavitt on topic Wasted cash on bad brakes
Tom P - the 2Fast shoes, even with proper adjustment and a few hundred miles on them, have no bite and honestly are just too dangerous. The Italian ones were night and day. Same with celox...tossed and put Vesrah on and same startling change.
22 Feb 2023 12:19 #4
Replied by Andy_C on topic Wasted cash on bad brakes
I ended up fitting EBCs to the 400 C, very dissapointed to start with but after they bedded in they seem fine.
I bedded mine in by doing about 10 runs up to about 40 MPH and then stopping with front only, then back only, leaving a few minutes in between for them to cool down.
I then took it up to 50 ish MPH and repeated the cycle, takes a while but the results were good.
As I say they work pretty good and seem to keep improving with mileage as you would expect.
Is it a bedding in issue or are they just crap linings ?
Ex Yam DT400C, Triumph Trident 660, Triumph 865, Kawasaki KH 400
23 Feb 2023 08:00 #5
 I have about 1,600 miles on my 2Fast front shoes and they're fine. No issues stopping. I have SOK shoes on the back.
23 Feb 2023 09:21 #6
  • msavitt
I prefer to not refer to weren't close to safe even with proper bedding/break in and adjustment....
23 Feb 2023 14:16 #7
Total rubbish as well as being dangerous then.
24 Feb 2023 00:54 #8
Msavitt, which bike are these on? Maybe the way we ride makes a difference as well. I don't like front brakes to be too grabby, and downshift a lot. With the shoes I have I can make emergency stops quickly on my CT-1, but maybe on a heavier bike they would be less effective? They have water slots, so a bit less effective surface area.
24 Feb 2023 08:43 #9
  • msavitt
One set went onto a Dt400E front, the other front of an R5C
I do not see this a matter of riding style, adjustment, bedding, all though those are valid factors for sure. In these cases its night and day difference between the ones that work and the one's that don't, the only variable is the low-quality friction material.
I am over the cash, having tossed them in the trash. I highlighted this so others don't waste hard earned cash junk that cannot be returned once used.
24 Feb 2023 09:59 #10
