Thicker Head Gasket for the RT1,2,3 to ease starting.
- 1971DT250
Thicker Head Gasket for the RT1,2,3 to ease starting. was created by 1971DT250
As I get older I'm finding it necessary to make it easier to start and ride these bikes. I installed a .125" thick head gasket in my '71 RT1B based on forum member SHYTED recommendation. Cleaned it with Brakleen, sprayed Copper-Coat on both sides, assembled it. Torqued the head bolts. Rode it for 10 miles, let it cool down and retorqued the head bolts. It is easier for me to kick with the reduced compression. It has a very slight reduction in power only noticeable when going up a long steep hill. I plan to install it in 2 of my RT3s.
coppergaskets.us/
coppergaskets.us/
The following user(s) Liked this Post: Enduronut, SKYDANCER46, JayB
19 Feb 2023 17:50
Replied by RT325 on topic Thicker Head Gasket for the RT1,2,3 to ease starting.
Wow, you have a stack of them there. are you selling some. Interesting info once again thanks.
19 Feb 2023 17:57
- 1971DT250
Replied by 1971DT250 on topic Thicker Head Gasket for the RT1,2,3 to ease starting.
I bought enough to do all of my regular riders plus the 5 NOS cylinders I have. I plan to get another 50 years out of these bikes.
The gaskets are available and are reasonably priced.
19 Feb 2023 18:00
- 1971DT250
They are also pretty.
The following user(s) Liked this Post: RT325, SKYDANCER46, JayB, Ht1kid, Sneezles61
19 Feb 2023 18:08
- SKYDANCER46
Replied by SKYDANCER46 on topic Thicker Head Gasket for the RT1,2,3 to ease starting.
If i owned a 360 this would be the 1st thing i would buy for it. Although i can't remember the last time being kicked back from any that i did own. I always gave it a good swift kick and followed thru all the way down with the lever.
19 Feb 2023 18:15
- 1971DT250
I installed this because it takes less strength to kick it.
Did I mention that the older I get the better I was?
- SKYDANCER46
Yep! that's why i moved down to the 250 club. Lol!
19 Feb 2023 18:46
- shyted
Replied by shyted on topic Thicker Head Gasket for the RT1,2,3 to ease starting.
They work a treat and are $17 a pop .
Regarding kick backs.
I have a CT3 . It's a while since i started it up but i recently did so.
I had my work boots on.
Right at the end of the kick stroke it popped back . The kick start shot straight from under my foot.
One month later , i still have a nasty painful thickening of the muscle below the inside of my knee.
I already have a scar there from a previous encounter with a BSA Bantam which resulted in 30 stitches and a limp for a couple of years . I was 14 years old then.
My 360 is a piece of cake to start now.
The following user(s) Liked this Post: 1971DT250, Pete-RT1, Sneezles61
20 Feb 2023 07:49
Really the decomp if working right should soften the kick more than a thick head gasket would. But if it makes for a softer motor when running then must be good. I worry about the squish not being--'squished so to speak'. Those motors seem to want to detonate at the slightest provocation. But if she's good then we're all learning & that's a good thing.
20 Feb 2023 12:43
- msavitt
Replied by msavitt on topic Thicker Head Gasket for the RT1,2,3 to ease starting.
cool gaskets
does the RT1 have a compression release like the ones on my DT360 or 400?
these seem to really work well when adjusted properly, I know they make a big difference because I have tested the kick with cable slacked out
21 Feb 2023 10:17
