At/ct seal questions
  • Papawhellie
  • Papawhellie's Avatar Topic Author
At/ct seal questions was created by Papawhellie
On the trans diagram it shows push rod seal 93109-06060-00. Where is this located and it it replaced without splitting cases? Also the IT crank seal Mark T mentioned on an old post 93103-25125-00 I assume will fit the AT As the AT/CT seal part number is the same?
22 Jan 2023 09:15 #1
Replied by MarkT on topic At/ct seal questions
Pushrod seal is located under side cover just forward and above the drive sprocket.
I'm not aware of any oil seal on a Yamaha Enduro that requires case splitting to change...  clutch pushrod seal on AT/CT definitely does not.
And yes, crank seals are the same size on all the Yamaha 125/175 Enduros from 1969 to 1981.  IT175 seal works  on any of them.
The following user(s) Liked this Post: shyted, JayB, Schu, Ht1kid
22 Jan 2023 10:44 #2
