[Help] with my '73 DT3 250, having ignition issues
- AirborneSilva
Replied by AirborneSilva on topic [Help] with my '73 DT3 250, having ignition issues
My guess would be carburetion...
12 Apr 2023 17:18
#121
Replied by RT325 on topic [Help] with my '73 DT3 250, having ignition issues
Not sure if i'm up on the play with this story. But the last video where it only just runs sounds ignition like points are miles too wide &/or plug way too wide, maybe both. What's been going on. Have you been altering points out of range. Going back a page or two there's a video of it reving clean to the point of being rich & safe at max revs, just maxing out a bit rich on the main jet. Not forgetting the tiny Oring but if it was 'that' it'd be a lot richer & limited--i guess depending how bad it's leaking fuel past to bypass the main jet. But talking the curren vid where just starts then misfires & stumbles--reffer to my first sentence.
12 Apr 2023 17:33
#122
Replied by MarkT on topic [Help] with my '73 DT3 250, having ignition issues
If nothing was changed or "fixed" recently, put in a new properly gapped spark plug.
12 Apr 2023 18:38
#123
- Mothersbaugh
Replied by Mothersbaugh on topic [Help] with my '73 DT3 250, having ignition issues
Did you bleed the oil pump to get all the air out of the lines? It will run ragged, as the mixture it is burning will not be consistent with air in the lines. Do you have at least a half tank of oil while you are trying to solve this problem? You don't want it to be gulping air through the hose from the tank to the pump.
12 Apr 2023 22:27
#124
- automan
Replied by automan on topic [Help] with my '73 DT3 250, having ignition issues
Flywheel slipped
cliff
cliff
13 Apr 2023 00:57
#125
- 19stuberd
Replied by 19stuberd on topic [Help] with my '73 DT3 250, having ignition issues
Thanks for playing everyone, I think that I've found our issue. See if you can guess from the first video and then you'll see in the second. I think it's pretty obvious what I need to replace, no spoilers here
photos.app.goo.gl/mN113o9sAYwA1oD3A
photos.app.goo.gl/8Lq73UDyNQCRMtDc7
13 Apr 2023 11:01
#126
- 19stuberd
Also thanks for the reply Mothersbaugh, I did in fact bleed and purge the lines thoroughly, especially since I did the test where you rotate the pump 200 times to check oil output at least 3 times lol. Good to check though, I almost didn't check that before!
13 Apr 2023 11:04
#127
Yamaha have black oil lines so we won't worry, & never a problem providing oil in the tank.
13 Apr 2023 16:03
#128
