DT2 Clutch Release
- AirborneSilva
Replied by AirborneSilva on topic DT2 Clutch Release
You are going to need to remove the push lever assembly from the side casing, the plastic worm gear is pressed on, as will the new brass one be. Mine was cracked in two places so it wasn't difficult to remove it. You could probably carefully use a dremel and cut it off, being careful not to damage anything. But be sure to mark it's position prior, can't stress that enough.
29 Nov 2022 09:21
#21
- phrog44
Replied by phrog44 on topic DT2 Clutch Release
i think i may be screwed. The worm gear was frozen into the case. When I tried to move the push lever assembly, it just slipped at the shaft, losing any indication of the placement of the worm gear. I was able to eventually get the worm gear out after the push lever was completely removed but, I have no way to know how the new gear has to be placed on the shaft. Is there any way to find the orientation of the original installation?
29 Nov 2022 12:12
#22
- AirborneSilva
The only way I can think of is slip the new worm gear in where it belongs then on the other side of the side case you might be able to match up the push lever assembly in it's proper orientation and possibly make the marks on push lever assembly, hope all that made sense...
29 Nov 2022 12:31
#23
- phrog44
Yes, that makes sense. I'll try that.
29 Nov 2022 12:43
#24
- AirborneSilva
Good luck brother!
The following user(s) Liked this Post: phrog44
29 Nov 2022 12:43
#25
- Sneezles61
Replied by Sneezles61 on topic DT2 Clutch Release
KDI sent a paper the shows you where to align things… just read it a couple of times.. look carefully..
Sneezles61
Sneezles61
29 Nov 2022 13:30
#26
- phrog44
Is there something attached that i am missing, or, is this something i can expect to receive from KDI?
29 Nov 2022 15:52
#27
- AirborneSilva
The only thing/part you will get from KDI is the worm gear itself.
29 Nov 2022 16:14
#28
Replied by MarkT on topic DT2 Clutch Release
Sounds to me like Sneezles got an instruction sheet with his... so you should too.
29 Nov 2022 16:36
#29
- Sneezles61
And believe me…. I need all the help I can get!
If I knew how to post a picture of that, I would do just that..
Sneezles61
Sneezles61
The following user(s) Liked this Post: MarkT, Ht1kid, phrog44
29 Nov 2022 17:01
#30
