No fuel at the spark plug
  • Eric72AT2
  • Eric72AT2's Avatar Topic Author
No fuel at the spark plug was created by Eric72AT2
I believe I have fuel in the carb bowl but not at the plug
Sent from my iPhone using Tapatalk
17 Sep 2022 15:24 #1
Replied by RT325 on topic No fuel at the spark plug
If the carb is blocked in the jets but choke jet is clear then plug should get wet on a closed throttle while kicking or electric starting. So first off does it suck against your hand over the carb on open throttle while kicking over or using electric. If it's definitely not sucking then crank seals popped out is first thought & likely the left side or I'd think plug would be oily if right side popped. Partzilla shows a retainer on both sides. But a good crankcase explosion or a case full of fuel then kicked over hard can force the retainers bent away on the right side. Not sure if the left has two screws so may go right over & be well retained--but strange things happen under pressure. As usual just guessing without being there.
17 Sep 2022 17:50 #2
Replied by Clegg on topic No fuel at the spark plug
Check your float level, may be too low.
18 Sep 2022 16:01 #3
