73 DT250 not running right
- 999Homer
73 DT250 not running right was created by 999Homer
Hi just started my bike up and seems to only want to run on choke turn off the choke and it cuts out was fine before but hasn’t been started in a few months any ideas
19 Aug 2022 09:05
- AirborneSilva
Replied by AirborneSilva on topic 73 DT250 not running right
Carb gummed up...
19 Aug 2022 09:14
Replied by MarkT on topic 73 DT250 not running right
pilot jet plugged up/restricted
19 Aug 2022 10:21
Replied by RT325 on topic 73 DT250 not running right
I'll go--everything bunged up. Time for a good clean. Could pull the carb bung-mainjet first to let a bit drain through clean & check the main jet as has to go through there to get up the needle & into the motor.
19 Aug 2022 16:30
- 999Homer
Replied by 999Homer on topic 73 DT250 not running right
Petroleum tap is also leaking like a bastard when I turn fuel on am I right in thinking just need to replace the rubber with the 4 holes in in the tap
20 Aug 2022 13:16
- Sneezles61
Replied by Sneezles61 on topic 73 DT250 not running right
There is a rubber O-ring around the fuel selector lever…
I’ve been fighting with mine… I ordered a new petcock… once I get it, and if it all fits and doesn’t leak, I’ll tell about it…
Sneezles61
Sneezles61
20 Aug 2022 15:19
- AirborneSilva
I've been fighting mine as well, rebuilt it but still wants to leak at times so I'll be looking at buying a new one too.
20 Aug 2022 16:04
New rubber should fix it. I turned mine over which helped but they can get ripped between the holes & then ya out of luck. Gotta be careful not to trap the wavy washer screwing the plate on too. I used to give the wavy a bit of a bend to increase tension but probably only works in theory.
20 Aug 2022 17:31
