1973 Yamaha CT3 - starts and revs full throttle
- Jogar
Replied by Jogar on topic 1973 Yamaha CT3 - starts and revs full throttle
So, it’s down to about 4200 rpm, I loosened the carb bolts.
odd thing, when I put the choke back in (or turn it off) it revs way higher.
John
John
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
10 Aug 2022 13:52
#11
Replied by Ht1kid on topic 1973 Yamaha CT3 - starts and revs full throttle
Did you check your carb slide?
The following user(s) Liked this Post: Jogar
10 Aug 2022 15:25
#12
The back of your carburetor should look like this
10 Aug 2022 15:38
#13
- AirborneSilva
Replied by AirborneSilva on topic 1973 Yamaha CT3 - starts and revs full throttle
With it running spray some WD40 around suspected areas, intake, cylinder base gasket and head. If there's an air leak in those areas you'll find it.
10 Aug 2022 16:37
#14
Replied by RT325 on topic 1973 Yamaha CT3 - starts and revs full throttle
Take The Carb OFF, & without removing the slide look through it & tell us if you see us waving the other side. Ok I'm being stupid [or am stupid] but serious also. You shouldn't see any daylight under the slide if shut right down. Check that first or ya chasing your tail in my opinion.
The following user(s) Liked this Post: MarkT, Jogar, Sneezles61
11 Aug 2022 00:13
#15
- Jogar
It does ! It’s strange though that it runs at 4000 rpm with the choke on? Then revs up crazy but steady to like 8000 when I turn the choke off
*would it make a difference if my exhaust pipe was on?
it’s off.
it’s off.
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
- Sneezles61
Replied by Sneezles61 on topic 1973 Yamaha CT3 - starts and revs full throttle
No… air is getting in somewhere, hence the idea of spraying around the intake manifold and jug.. if it starts to rev… give it a moment to clear and give it a shot again…… and like RT325 states.. could be the round slide is not seating… it takes a curious mind to problem solve this issue… keep after it, you’ll find it
Sneezles61
Sneezles61
11 Aug 2022 13:25
#17
- Jogar
I’ve sprayed some carb cleaner around the intake, but haven’t had any change in idle from that. I’m perplexed
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
11 Aug 2022 13:37
#18
ok but get up a photo looking in at the slide with a mirror behind it. Like in post #13 carb pic, look in there & out the back. Shouldn't be daylight or if so how much.
11 Aug 2022 21:10
#19
- Jogar
Ok, so here’s where I’m at. I looked in the back, it was sitting abnormally high. So I loosened the throttle up near the hand grip to let the slide down more.
after doing that, it idles decently normal, but I experience a bit of rev hang when I’m giving it throttle.
John
John
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
13 Aug 2022 10:46
#20
