Special needle for 74 DT360A carb?
  • matt6866
  • matt6866's Avatar Topic Author
Special needle for 74 DT360A carb? was created by matt6866
Hi guys, picked up my 3rd DT (I’m hooked) at this years vintage days event at mid Ohio.  I got a 74 DT360A that is pretty much complete except for a carb slide, spring, needle and retaining clip.  I called up Sudco, and talking with them they made it sound like finding a needle was going to be tough.  I was able to measure the inside diameter of the bore on my carb and order a slide and retaining clip plate that should work from them, but the needle is what I’m wondering about.  The VM30SS carb calls for a 5EJ8 needle but the only ones I’m finding on eBay are for Kawasakis.  Can I get away with using the one attached?
I didn’t think it would be this difficult to get a couple carb parts!
thanks
Last edit: 29 Jul 2022 20:17 by matt6866.
29 Jul 2022 20:16 #1
Replied by MarkT on topic Special needle for 74 DT360A carb?
Mikuni 5EJ8 is a Mikuni 5EJ8.  Period.
Mikuni tuning manual will explain the needle tapers at least a little bit...
29 Jul 2022 20:46 #2
  • matt6866
Replied by matt6866 on topic Special needle for 74 DT360A carb?
ok thank you!  I just wanted to confirm it would work.  I’ll probably order that up
Last edit: 30 Jul 2022 05:49 by matt6866.
30 Jul 2022 05:47 #3
Replied by msavitt on topic Special needle for 74 DT360A carb?
make sure your main and pilot are at least as large as what's specified.
I used a #55 vs #50 for pilot, I think it runs better
but my main point is if your main is too small you can melt you piston, which I did with a #140 main in place!
The following user(s) Liked this Post: matt6866
30 Jul 2022 20:48 #4
Replied by yamahahaha on topic Special needle for 74 DT360A carb?
Did you find the 5EJ8 needle yet ?
03 Aug 2022 04:52 #5
