Replaced crank seal now clutch won’t engage
Replied by RT325 on topic Replaced crank seal now clutch won’t engage
Is it possible the plates are not stacking up enough & the pressure plate is bottoming on the hub before compressing plates. Other than that it sounds like the adjuster in the actuator wants letting off plenty.
DT3 won't have a splined pressure plate so can't go wrong like the splined one can be fitted wrong & not go on fully. Ignore that bit as just confusing things except i run a later splind pressure plate on something of mine.
15 May 2022 20:46
#11
Sorry ignore my above post. I'm a day behind as usual & you have her running. good job.
16 May 2022 03:51
#12
- bhepp15
Replied by bhepp15 on topic Replaced crank seal now clutch won’t engage
Just got it retimed and a new crank seal on dry side. It started great, hasn’t been run in about a month and it’s sounding better than I’ve ever heard it. Take it out for a ride and it wants to die on deceleration. I’ve been trying to adjust the clutch but I can’t get it to fully disengage. Might have to dig into the other side and make sure I didn’t mess anything up over there? Here’s a picture of the actuation device.
21 Sep 2022 15:32
#13
- bhepp15
Also when adjusting I am disconnecting the throttle cable loosing the lock nut and moving the screw then holding the screw in place untill nut is tight. I’ve been tightening it untill I hit resistance and then 1/4 turn back but have tried many other spots as well.
21 Sep 2022 15:34
#14
- AirborneSilva
Replied by AirborneSilva on topic Replaced crank seal now clutch won’t engage
Hey Brock, I'm sure you meant clutch cable and not throttle cable, anyway I'm wondering if the plastic piece in the picture below isn't returning all the way, flush with the case. And before anyone says anything I've replaced the broken plastic piece with the brass one from KDI.
21 Sep 2022 16:13
#15
Clutch cable not throttle i'm sure you mean't, no worries. The actuator on those does split then you lose half the useful movement. Easy to check just turn it out to inspect & grease it while its out. Otherwise if it feels like its possitive & lifting the clutch then yep ya might have to 'go in'. Just been in my 360 clutch as it happens.
Sorry haha, typing too slow & above beat me to it. Thats good.
- AirborneSilva
21 Sep 2022 16:18
#17
- bhepp15
Nothing is broken, sadly haha I find myself wishing to find some something broken more than most I think. What could be another cause on the other side.
21 Sep 2022 16:39
#18
- AirborneSilva
My only other guess with my limited knowledge is the springs on the clutch pressure plate are maybe wore out...
21 Sep 2022 16:44
#19
- bhepp15
That is possible, only issue is it was all good before I replaced the plates. I did remove those rubber rings in the clutch pack but I thought that was a suggested thing to do.
21 Sep 2022 17:48
#20
