Ct175 oil pump shaft seal dimensions
  • s900t8v
  • s900t8v's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Ct175 oil pump shaft seal dimensions was created by s900t8v
Hey
My ct175 oil pump shaft seals hve failed.
just wondering if anyone knows the seal dimensions I’m in Australia and see there are kits in USA but very expensive.
thanks.
Ed
1976 Yamaha AG175 cafe
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
20 Mar 2022 14:02 #1
Replied by MarkT on topic Ct175 oil pump shaft seal dimensions
Some yamaha seal numbers I've used.  Should be available
Also look at earlier bike parts lists as they often have pump parts diagrams. Pumps haven't changed much.
Small internal driveshaft seal: 93104-06108-00-00
Primer end seal: 93101-10090-00-00
Pump seal : 93104-14059-00-00
You can also measure old seals or housing and shaft to see if you can find generic seals someplace
Last edit: 20 Mar 2022 14:20 by MarkT.
20 Mar 2022 14:18 #2
Replied by Gr8uncleal on topic Ct175 oil pump shaft seal dimensions
I would imagine that the part numbers that Mark has provided from the US model will be the same as fitted to your bike, but you might want to check, just to be sure.
If you still need the dimensions, as opposed to just ordering original Yamaha parts, then look for any photos of the part numbers on sites such as CMSNL, Partzilla, fleabay and archive internet pictures. Seals often have the dimensions stamped on them, so you should be able to see from the images what sizes the seals are. I would cross reference three or four different images, just in case some have been incorrectly listed.
20 Mar 2022 15:24 #3
  • s900t8v
  • Platinum Member
  • Platinum Member
Replied by s900t8v on topic Ct175 oil pump shaft seal dimensions
I ended up just converting it to premx
man the EGTs are way down now it was running up to 450celsius haha now 220 at WOT
1969 Yamaha L5T
1979 Yamaha Rx125
1954 Puch 175 Sv
1951 Puch 250TF
23 Mar 2022 15:43 #4
