DT1 Headlight??
- Burlybilt
DT1 Headlight?? was created by Burlybilt
Anyone know a source for the sealed headlight for a 1970 DT1???
Or an alternative that can be used??
Thanks!!
Thanks!!
25 Feb 2022 17:45
- adguy2112
Replied by adguy2112 on topic DT1 Headlight??
I put in a 4020 6V from Napa auto parts.
25 Feb 2022 19:57
- goatboy56
Replied by goatboy56 on topic DT1 Headlight??
Hi Adguy:
Any chance you have a different Napa number as went to 3 different stores and they could not come up with a 4020. I ended up getting a Norman Lamps 4020 from Amazon for $26.00.
Thanks,
John
Thanks,
John
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
26 Feb 2022 04:54
- Burlybilt
Replied by Burlybilt on topic DT1 Headlight??
Thanks-
The original is super hard to find...
Looks like it'll have to be held in place/adjusted by other means...
Dave
Dave
26 Feb 2022 16:48
Replied by MarkT on topic DT1 Headlight??
You're not getting a whole lot of responses because this topic has been discussed here probably more than any other... there are hundreds and hundreds of posts on headlight replacement. Search is your friend.
26 Feb 2022 19:12
- Burlybilt
Thanks again for the replies-
I ordered a Napa 4020.
Size wise there are many 5 3/4" bulbs out there.
The issue is the original has several integral mounting/adjustment tabs that the replacements don't...
Dave
Dave
27 Feb 2022 07:54
Replied by Gr8uncleal on topic DT1 Headlight??
This is the part with the replacement bulb facility that was fitted originally (see photo).
An early CT1 headlight would likely work as well.
If you manage to find one, then you will need a different bulb holder and pigtail connector as well.
Later models got rid of the (useless!!) brackets and adjustment hardware and just clipped the bulb into the chrome ring.
You can get the clips from Yamaha or someplace like MikesXS. www.mikesxs.net/yamaha-xs650-headlamp-w-clips-pk-5.html
If you are doing a "concours" restoration then you can spend a small fortune on a NOS replacement.
My preference is to use a very common H4 reflector and install the appropriate 6v H4 bulb... costs a little more than a sealed beam initially but subsequent bulb replacement is easy/cheap... as is conversion to 12v.
27 Feb 2022 08:59
